Old 07-06-2018, 05:00 PM   #1
FireSurf's Avatar
Dometic Refrigerator Not Working But Freezer Does
I have a 2015 3ds and the freezer is getting cold but not the refrigerator. Any ideas?
2015 FR3 30DS
FireSurf is offline   Reply With Quote
Old 07-06-2018, 05:10 PM   #2
fonzie's Avatar
Usually takes between 8 to 24 hours for fridge to cool to below 40 f if gas/electric refrigerator.
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 07-06-2018, 05:23 PM   #3
Flybob's Avatar
Rv fridges are different than residential fridges. An empty fridge will not feel cold and will warm up quickly when opened. Fill it with cold items and give it 8-10 hrs. Remember fridge removes heat energy from items. There is almost no mass in an empty rv fridge to absorb heat energy so it will warm up quickly. A full fridge has lots of cold mass to absorb heat energy hence it will remain cold. Best bet is to get a wireless thermometer so you can check without opening. https://www.amazon.com/AcuRite-00986...ge+thermometer
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-07-2018, 07:26 AM   #4
lacoles
lacoles's Avatar
We have a 2014 FR3 30DS and are having the same problem. We tried the troubleshooting manual and bypassing the circuit board and using strait electric from a modified cord can get 0 degrees in freezer and 32 in fridge . We replaced the circuit board. No luck. We replaced the thermistor also still doesn’t work. We’re going to call someone to look at it. Don’t know what else to try
lacoles is offline   Reply With Quote
Old 07-07-2018, 07:57 AM   #5
Carknocker Family
Ida Ratherbe Camping's Avatar
Maybe misunderstanding, but how much colder than 0 and 32 do you want? Any colder in fridge and it becomes a freezer. Or is this by bypassing everything?
Ida Ratherbe Camping is offline   Reply With Quote
Old 07-07-2018, 11:07 PM   #6
lacoles
lacoles's Avatar
The problem is it will not cool the fridge on gas mode or when plugged into electric when circuit board is hooked back up
Old 07-09-2018, 11:19 AM   #7
HortMi's Avatar
Just asking, have you adjusted the temp setting? I have a double door(one freezer and one Fridge) and just found out how to adjust the temp. I was cleaning the coils and accidentally turned it down.Freezer still was freezing but the fridge was cooling to about 50. I adjusted it and now the fridge is 38 to 40.
HortMi is offline   Reply With Quote
Old 07-09-2018, 08:47 PM   #8
TLAK's Avatar
The temp adjustment on these RV refrigerators is not intuitive. Open the door and look at the top shelf. There is a plastic slide on the right side of cooling fins. If you haven't done so already, play with it and see if it helps.
2015 FR3 30DS
Towing 2016 Chevy Sonic LT
TLAK is offline   Reply With Quote
Old 07-09-2018, 11:04 PM   #9
rk06382's Avatar
The one thing that was not covered is the plastic slide that holds the thermistor. Mine was loose enough that when I pushed the slide it up the fin, the thermistor slid down the sleeve. Moving the slide did nothing to the thermistor.
I had to drill a small hole in the slide. Then I used a tie-wrap to clamp the thermistor in the slide.
Now when I moved the slide up the refridgerator got down to 34F.
Amazon: AcuRite 00986A2 Refrigerator/Freezer Wireless Digital Thermometer
Name:	Digital Thermometer 510mOY9AjhL._SL1000_.jpg
Robert
2018 FR3 28DS
Samlex EVO-3012 Inverter/Charger| 400ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | Dometic 320 | SnapPads |
Solar Power & Battle Born batteries thread
rk06382 is offline   Reply With Quote
dometic, refrigerator
