Old 05-31-2016, 10:05 PM   #21
Ours failed due to wind gusts at the beach earlier this year. I replaced it with a stock unit from Auto Zone, Mighty Lift by AVM Industries part number C95251. It is a 30# strut which requires more force to close the door but does a great job at holding the door with strong wind gusts. No problems with the replacement so far.
The replacement unit seems to be better built and hopefully will hold up longer.
Weatherwithyou is offline   Reply With Quote
Old 06-05-2016, 07:47 PM   #22
Technorick's Avatar
When my door gas piston apparently lost its suction my door would waggle in he wind. I added an aluminum bar about 36 inches that mounts to a marine style hinge mount. One on the passenger side wheel well and another on the door. Stainless screws and fender washers. Holes in the bar allow the bar part to be installed with pins. Pins attached to chains to the bar ends. The bar creates a triangle and holds the door open solid. Pics tomorrow.
After adding the removable door stay bar I found the part number on gas shock and ordered it on line. I got the 15lb. version and I got a pair so now I have a spare.
I suspect as we are posting about this that they have a short 20 month life span.
2014 FR330 DS
Technorick is offline   Reply With Quote
Old 06-06-2016, 02:53 PM   #23
Technorick's Avatar
2014 FR330 DS
Pics
Name:	ImageUploadedByForest River Forums1465242718.727149.jpg
Name:   ImageUploadedByForest River Forums1465242738.794701.jpg
Name:   ImageUploadedByForest River Forums1465242764.095444.jpg
Name:   ImageUploadedByForest River Forums1465242779.494919.jpg
2014 FR330 DS
Old 06-06-2016, 08:35 PM   #24
H3N
H3N's Avatar
We use a fresh bungee cord to accomplish a similar effect (we're not very handy :-)
Three Woading Wyrding Wandering Widows
1998 Amber the ancient shape shifting couch surfing cat
2018 XL 369DS, aka Uncle George Junior
2016 Ford CMax Engeri plug in hybrid “Kona Car” (toad)
H3N is offline   Reply With Quote
Old 06-06-2016, 08:49 PM   #25
Moved the anchor points on the door and the trailer and they now work great! Door opens to within 2" of awning strut and when it is within 6" of closing it helps close the door.
Name:	Both anchors relocated.JPG
ID:	110342   Click image for larger version
Name:	Close up door anchor relocated.JPG
ID:	110343   Click image for larger version
Name:	Close up relocated anchor on trailer.JPG
ID:	110344   Click image for larger version
Name:	Relocated anchor on trailer.JPG
ID:	110345   Click image for larger version
Name:	Relocated strut.JPG
door, gas
