Old 06-29-2014, 02:44 PM   #1
StephanFR3's Avatar
Door hard to close.
Found door screws at hinges not holding but stripping. Thinking of pop riveting.
StephanFR3 is offline   Reply With Quote
Old 06-29-2014, 05:33 PM   #2
Is it the entry door?
FR3-SalesTrainer is offline   Reply With Quote
Old 06-29-2014, 05:53 PM   #3
StephanFR3's Avatar
Yes, and it popped open on road.
Old 06-29-2014, 05:56 PM   #4
StephanFR3's Avatar
All screws were loose causing door to sag. Making door latch to slightly miss. Tightened screws but several won't hold due to thin sheet metal.
Old 06-29-2014, 06:16 PM   #5
StephanFR3's Avatar
Pic
Old 06-29-2014, 06:19 PM   #6
3/16" pop rivets.
Old 06-29-2014, 06:22 PM   #7
StephanFR3's Avatar
How long?
Old 06-29-2014, 06:25 PM   #8
1/2" or 5/8" should be more than long enough.
Old 06-29-2014, 06:26 PM   #9
StephanFR3's Avatar
Old 06-29-2014, 06:54 PM   #10
StephanFR3's Avatar
Rivets worked. I should submit my time for warranty work.
Old 06-29-2014, 06:54 PM   #11
Try bigger diameter screws first. If, the pop rivets don't hold you will have to drill them out to try something else. Worth a try. Suggest you start them with a drill motor, then hand tighten them to snug.
Old 06-29-2014, 06:58 PM   #12
Please email me on this as I would like to pass it on to the engineers. I can be reached at Ericb@forestriverinc.com
Old 06-29-2014, 07:00 PM   #13
StephanFR3's Avatar
Bigger screws didn't hold. BTW other side of hinge is pop riveted from factory.
Old 06-29-2014, 07:10 PM   #14
Please email on this so I can double check with me engineers. Thanks ericb@gorestriverinc.com
door
