Originally Posted by frankie D
Looks like you need to tilt the RV in order to drain the tank
Not the best design
Often the tank tap is on the side of the tank, not the bottom. Given the margin needed for the tap flange, etc. it might be an inch from the bottom.
You need to look at the tank to see which side the connection is on: front back, driver-side, passenger-side, and then park so that side is down.
