Old 06-14-2019, 06:30 AM   #1
Draining fresh water tank
Is there another way to completely drain the fresh water tank the low point drain still leaves a couple of inches of water in the tank
frankie D is offline   Reply With Quote
Old 06-14-2019, 06:34 AM   #2
I think my hubby would leave it open a bit like we drove around to dump etc..to let it jostle around
2 friends is offline   Reply With Quote
Old 06-14-2019, 06:55 AM   #3
Flybob's Avatar
Unfortunately not normally. I had access to the top of the water tank in a previous TT and cut a hole and added a marine deck plate ( see photo). If I needed to drain the tank completely, I would open the deck plate and use a wet/dry vac. Other than this there is not really a way.
Name:	deck plate.jpg
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-14-2019, 06:59 AM   #4
just for clarification, are you trying to drain it with the low point drain or the fresh water tank drain?
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 06-14-2019, 07:12 AM   #5
Thurman's Avatar
I don't use my fresh water tank, I'm not a boondocker, nor have I needed to use the FW tank. Twice a year I do add about ten (10) gallons of water to the tank with a bottle (16 oz. ?) of Hydrogen Peroxide just before going out on a trip. This solution sloshed around while going down the road to help keep the tank clean. Before dumping the tank I fill it completely and let it sit a couple of days before draining. Clorox, being hydrochloric acid, is not good for plastics. Not that a diluted solution will eat a hole in your tank. I prefer TO as a disinfectent.
2015 FR Freedom Express 310BHDS pushing a 2014 GMC Sierra CC
Thurman is offline   Reply With Quote
Old 06-14-2019, 07:42 AM   #6
XenoRev's Avatar
I'm not sure that Clorox is hydrochloric acid.
I believe it is sodium hydroxide a base, not an acid.
That said, it can be hard on plastics if not correctly diluted for sanitizing.
It seems to me the recommended dilution is something like 1 cup bleach to 25 gals water.
2018 Salem 27DBK
2004 Ram Quad 1500
Days past:1996 Coachman Capri-Ruby Ed. 27DS
1995 GMC Yukon Sport
1986 Jayco1016PUP
Days Camped:'13-10 '14-20 '15-6 '16-9 '17-14 '18-3
XenoRev is offline   Reply With Quote
Old 06-14-2019, 08:06 AM   #7
X2.
You simply CAN NOT drain the fresh water tank with the low point drains.
The fresh water tank should have its own drain.
Days Camped: '17=30 '18=51 '19=58 '20=21
Old 06-14-2019, 08:20 AM   #8
jeff64's Avatar
Bleach is commonly, sodium hypochlorite but can be hydrogen peroxide. I gotten into the habit of draining everything when I leave the dump station. I have ball valves on the low point drains and the Camco WH anode with petcock drain. Must take all of 30 seconds to open all the drains. By the time I get home, everything is empty. Especially if I'm not going out for a few weeks.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 06-14-2019, 12:37 PM   #9
Agreed a dilution of something like 1:200 is going to create no problems, but how hard can bleach be on plastic? It comes in plastic bottles. I'll bet some of it stays on shelves for years. Same for drain cleaner and a lot of other caustic agents. We treat our water with bleach a few times during the year and have never had a problem.
As far as not needing fresh water, I guess we are weird, because one of the bonuses of owning an RV is having your own clean toilet available at all times while traveling. I always keep at least 5 gallons for just that purpose. Having the ability to wash your hands at any point is nice too.
mandb is offline   Reply With Quote
Old 06-14-2019, 12:51 PM   #10
BillyBass's Avatar
My old camper had a plug I replace it with a street l and a shut off value
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill ,Alley and Sierra
BillyBass is offline   Reply With Quote
Old 06-14-2019, 02:14 PM   #11
If there’s another drain for the tank where would it be
I have a 2018 30ds
Old 06-14-2019, 02:29 PM   #12
Mr. Dan's Avatar
I have a 2018 30ds
What do you mean "another drain"?
Conversations seem to imply more than one fresh water tank can't be drained completely. The references to "low point drain" concerned a semantics issue. Generally in the RV world, "low point drains" refer to 'typically' a single red and a single blue drain the two of which drain the water out of hot and cold water lines. The term "fresh water tank drain" usually refers to the drain for which you are concerned. My unit has it fresh water tank drain spun into the very bottom of the tank - and it does a fair job of completely draining the tank. Some units have the fresh water drain on the side of the tank which leads to your problem. Have you pulled down the bottom covering (if you have one) to see if your drain is on the tank's side OR is your tank under a bed, etc.?
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 06-14-2019, 06:52 PM   #13
Plug or sacrificial anode.
If that "old camper" had a Suburban water heater, the "plug" would have been about 5" long. Most of the length (excepting the threaded portion and head) would have been an aluminum or magnesium sacrificial anode. The notion is tht it corrodes first, before the inside of the tank. The principle is the same as the zinc coating on galvanized pipes or garbage cans. If you replace that plug with something else with no aluminum or magnesium,you are risking corrosion of the tank.
Of course, if your "old camper" had an Atwood water heater with aluminum tank, the plug is just a plug and there is no sacrificial anode.
Larry
Larry-NC is offline   Reply With Quote
Old 06-14-2019, 07:05 PM   #14
Mr. Dan's Avatar
Larry
I don't think Billy is talking about anything to do with the water heater. I think he's talking about the fresh water tank drain.
Old 06-15-2019, 01:12 PM   #15
My FR3 has the drain on the side and leaves water in the tank also. Try using the levelling jacks to lift the side up and most will drain out but not all. Driving around with low point drain plug open works fairly well also.
Poor design for sure and really the only fix is to add fresh water and drain occasionally.
2017 FR3 28 DS
cariboo camper is offline   Reply With Quote
Old 06-15-2019, 01:22 PM   #16
I have a 2018 30ds
No there is not. Low point drains will drain both water pipes and fresh water tank. On my 28DS low point drains are directly under water pump bay.
2017 FR3 28 DS
Old 06-19-2019, 07:50 AM   #17
rk06382's Avatar
I have a 2018 30ds
This is my low point outlet of my fresh water tank. Sorry about the focus. It has a Tee at the water pump before the low point drain.
Name:	FW Low Point 20180804_192604.jpg
Robert
2018 FR3 28DS
Samlex EVO-3012 Inverter/Charger | 600ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | SnapPads | SumoSprings
Solar Power & Battle Born batteries
rk06382 is offline   Reply With Quote
Old 06-19-2019, 10:35 AM   #18
Looks like you need to tilt the RV in order to drain the tank
Not the best design
Old 11-01-2019, 04:47 PM   #19
Fresh Water Tank Drain
Where you able to drain the tank by tilting the motor home? I ask because I have the same problem.
rosanne is offline   Reply With Quote
Old 11-01-2019, 05:33 PM   #20
rk06382's Avatar
I never worried about the last couple of gallons of water. If it freezes, it will do no damage.
An inch of water in the tank is okay. A little water needed for the tank heaters.
Robert
2018 FR3 28DS
drain, fresh water, tank, water, water tank
