Old 01-29-2016, 06:28 PM   #11
Tents2RV
linchat
I was able to lift the outside TV straight up and off to access the ports. I had to balance it with one hand and change the cable to the correct port with the other.
Hope this helps!
c0nnd0r is offline   Reply With Quote
Old 01-30-2016, 11:13 AM   #12
Originally Posted by linchat View Post
How do you access the ports on the outside TV? From the inside, behind the couch? I have yet to attempt to remove it from its mount or try to access the backside.
I wandered if the outside TV was setup with the inside DVD player. My inside TV of the kitchen in my 32DS is connected to the DVD, it seemed to only make sense the outside was as well. But outside does not work with DVD, no I know why.
To access the ports on the outside TV you hold both sides of the TV and lift up. The TV sits in two little brackets and easily lifts off. Once you switch the port on back, the outside TV will now play DVD's from the inside DVD player.
depmgt is offline   Reply With Quote
Old 02-11-2016, 08:11 AM   #13
After removing the tv just found the cable was loose. All was hooked up prop from forest river, just cable a tad loose. Thanks for reply. 2016 32 ds
linchat is offline   Reply With Quote
dvd
