Old 07-28-2016, 10:11 AM   #1
Electrical hook up
Is it possible to use a 50 amp pedestal with a adapter plug with a 30 amp system?
jbutch is offline   Reply With Quote
Old 07-28-2016, 10:15 AM   #2
wmtire's Avatar
Absolutely.
Although the 50 amp 120/240 volt pedestal has two 120 volt lines, the adapter terminates one of the legs in the adapter, and thus only one is available to your RV, as in a normal 30 amp outlet....so they just use the adapter and plug into the 50 amp outlet.
Many people do this when at campgrounds that don't have a 30 amp outlet, or many times the 30 amp outlet is weak/damaged due to it being used a lot more often than a 50 amp outlet.
You can get these adapters off Amazon, Camping World, just about any RV dealer, and even at Wal-mart stores in the RV section.
I prefer the dogbone type adapter (it looks like a dogs chew bone when laid flat), as it allows you to close the pedestal cover....whereas the straight plug type adapter usually will not.
dogbone adapter:
Straight adapter:
2011 Flagstaff 831 RLBSS
Why is no one ever the right amount of whelmed?
Old 07-28-2016, 01:07 PM   #3
waiter21's Avatar
Yes, I do it several times a year.
I have 30 amps in my Mirada, Occasionally when I plug into a pedestal, the 30 amp connector will seem loose. If they have 50 amps, I'll use my 30 to 50 adapter and plug into the 50 instead.
Bad / loose pedestal connections will damage your connector.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 07-28-2016, 01:54 PM   #4
Curiouser and Curiouser
[QUOTE=wmtire;1273466]Absolutely.
Thanks for the great advice - I didn't know that and have wondered what to do in the case of some sites that have only 50 amp outlets!
Finch is offline   Reply With Quote
Old 07-28-2016, 05:49 PM   #5
Thanks for the input.
electric, electrical
