Old 03-06-2018, 09:39 PM   #1
Electrical question
After setting for few months on shore power my generator won't start, awning won't work and radio in coach won't work. Checked batteries and all are charged, any ideas.
pseatower22 is offline   Reply With Quote
Old 03-06-2018, 09:53 PM   #2
Mr. Dan's Avatar
How did you check your batteries to know they are fully charged? Did you use a volt meter or other?
Old 03-06-2018, 09:56 PM   #3
I am assuming breakers and fuses have been checked?
Kimber45 is offline   Reply With Quote
Old 03-06-2018, 10:33 PM   #4
Generator won't start as in won't turn over or turnover and not start? Those are 3 unrelated things. We need more info. 12-volt lighting not working? 12-volt igniters on stove working?
Old 03-07-2018, 08:02 AM   #5
need a clarification. you used the word coach so I am assuming you are referring to a motor home that has both house and chassis batteries. which set did you check to say the batteries are charged?
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is online now   Reply With Quote
Old 03-07-2018, 08:15 AM   #6
The battery would have to be pretty damn dead for radio not to work. It works off the chassis battery assuming your talking about the dash radio. Please explain to us ALL that is not working.
Old 03-07-2018, 08:54 AM   #7
Exclamation
what yr,make,brand,model of coach do you have?
are you referring to the 'Chassis' batteries for the engine, or the 'House' batteries for the coach?
typically the items you are referring to that are not working are actually on the 'House' batteries, as to not run down the engine starting batteries.
Are you sure you have your 'Charger' ON while on shore power?
Are you sure your shore power is ON?
formerFR is offline   Reply With Quote
Old 03-07-2018, 09:03 AM   #8
Cavie,
Is your stove this way from factory?
In all the many campers I've owned or been in, I've never seen a 12v igniter to light the burners. Most have a knob that turns to create spark (piezo) and I have seen a very few with a AA battery igniter but never one connected to 12v.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 03-07-2018, 09:03 AM   #9
edm
Check to see that your main battery disconnect on the panel near the floor is on.
Just a suggestion.
edm is offline   Reply With Quote
Old 03-07-2018, 11:02 AM   #10
Cavie,
My bad, I was thinking WH and Furnace but my fingers were in charge.
Where's that damn edit button when you need it?
Old 03-07-2018, 11:57 AM   #11
How can I check the inverter for power? Everything so far checks ok when checked by guys in cg with volt meter???
Old 03-07-2018, 12:04 PM   #12
How can I check the inverter?
Old 03-07-2018, 12:36 PM   #13
Residental fridge? unplug the shore power and open the fridge door. Got light? TV on?
Old 03-07-2018, 12:40 PM   #14
Since the OP won't answer our questions my work in done here.
Old 03-07-2018, 01:09 PM   #15
Brother Les's Avatar
No they wernt... it was the ku-nut behind the wheel......
Brother Les
Old 03-07-2018, 01:38 PM   #16
Had a call from FR and all they come up with is the converter. Sorry I didn't answer fast enough, was on phone.
Old 03-07-2018, 04:35 PM   #17
Did you remember to plug the motorhome back in to itself
colourful64 is offline   Reply With Quote
electric, electrical
