Old 06-16-2017, 08:40 AM   #1
Jim Wiemels's Avatar
Entertainment System Question:
I have a FR3 30DS and was wondering if the dash DVD player is wired to the exterior TV to play DVDs or does the exterior TV only play regular TV channels. Thanks. Jim
Jim Wiemels is offline   Reply With Quote
Old 06-16-2017, 03:37 PM   #2
TLAK's Avatar
My exterior tv does play DVD just like the living room. Works exactly the same way. The bedroom one is not wired to the DVD
2015 FR3 30DS
Towing 2016 Chevy Sonic LT
TLAK is offline   Reply With Quote
Old 06-16-2017, 03:58 PM   #3
Thank you TLAK, is there a switch on the dash entertainment unit to play outside or does it play on both TVs if you have the right source selected on the TV ?
Old 06-16-2017, 06:51 PM   #4
After additional investigation, I found the yellow video connector disconnected behind the outside TV. It was very difficult to locate and reinsert.
Old 06-17-2017, 06:27 AM   #5
yes, a common problem ive read many times before. keep an eye on that yellow connector. put dash system on a/v and you should be good to go for both.
Combatcoal is offline   Reply With Quote
entertainment
