Old 03-27-2015, 01:23 AM   #1
Junior Retiree
Entry Lock Issue
On my 2014 FR3 the entry door will not close without pulling back on the handle as I shut the door. The retracting part of the lock mechanism is not hitting the striker plate properly, it's obviously protruding out too far and not hitting the striker plate with the sloped portion. This started doing this today, been out on the road for over a month. Anyone else run into this issue? I'm concerned this might be the beginning of an entry door lock mechanism failure (Trimark), not looking forward to being locked inside the unit!
Canuck2584 is offline   Reply With Quote
Old 03-27-2015, 07:39 AM   #2
bubbles's Avatar
Your FR3 might be a different animal but typical main entrance door latches are identical and are adjustable using a Philips screw driver. Maybe the FR3 went a different way. Mine occasionally has to be adjusted and sometimes will bind a little if leveling torqued the frame somewhat.
Old 03-27-2015, 10:35 AM   #3
Junior Retiree
Thanks for the info Bubbles, so I try the door this morning and all is good. The motorhome has not moved for a couple of weeks at our vacation location in Palm Springs. The only change from yesterday afternoon is the temperature, hitting over 100 degrees yesterday afternoon. Hard to believe this could be the culprit though??
Old 03-27-2015, 11:01 AM   #4
bubbles's Avatar
Sometimes a little white lithium grease or in a pinch WD40 does wonders. Happy camping. I'm done.
Old 03-27-2015, 10:51 PM   #5
Bobb36's Avatar
I have to keep retracting part of the lock mechanism lubed real good because of this reason and I cut and riveted a kick plate to the inside bottom of the door because the wind had bent the door at the bottom hinge.
2014 FR3 30DS
2014 JEEP WRANGLER WILLYS
Bobb36 is offline   Reply With Quote
Old 03-28-2015, 02:26 AM   #6
Junior Retiree
As mentioned above, the door closed without pulling back on the handle first few times I tried in the morning, wrote the update that all was well, then shortly after it's jamming again. Called Trimark, no screws available to adjust.Tried a bit of WD40, no luck. Maybe it is the heat causing metal expansion or warping.
Bobb36: do you lubricate the locking mechanism by taking off the inside faceplate or simply apply at the retracting bolt? WD40?
On a good note, confirmed with Trimark that I have the version of the entry lock that was redesigned due to many cases of mechanism failure. They were able to confirm via the serial numbers on the keys.
Cheers
Old 03-28-2015, 10:34 PM   #7
Bobb36's Avatar
simply apply at the retracting bolt then work in
2014 FR3 30DS
Old 03-29-2015, 06:26 AM   #8
wayne and sherry's Avatar
I use tri lube for keeping things moving nicely. It's a great product. I've been using this stuff for over 20 yrs. The locks all around JeNNY were starving for some lubricant and after giving ever lock on the unit some tri lube they all work very nice now.
JeNNY (FR3/30DS)
wayne and sherry is offline   Reply With Quote
Old 03-29-2015, 06:27 AM   #9
Name:	ImageUploadedByForest River Forums1427624849.395171.jpg
JeNNY (FR3/30DS)
Old 03-29-2015, 06:47 AM   #10
Ford Idaho's Avatar
Arrow
Metal will swell at 100 degrees, if there is a next time and you have a temperature gun get a reading of the surface temp of the area around the lock.
