Old 06-07-2015, 01:51 AM   #1
Entry step light On/Off switch addition
I want to be able to have the amber light that comes on when the entry door is open and turns off when closed (appears to be on a timer) be controlled by a switch so that I can manually turn the switch on or off.
The light has a male and female connector that when connected to each other powers the light. If this connection is no longer used and 12v power thru a switch is wired directly to the light lead connector will not using the factory light power lead effect the function of the steps in any way?
Paul
JABuyer is offline   Reply With Quote
Old 06-07-2015, 08:01 AM   #2
bubbles's Avatar
No. Same as bulb burned out. Go for it.
light
