Old 04-11-2014, 03:53 PM   #11
You'd be surprised how far down you will jump with flames nipping at your butt. We open ours for ventilation in the bedroom but you have to be careful as a swift breeze will jar it and it will fly open....My last fifth wheel I drilled a hole in the red handle and put a large toothpick in it to keep it from coming open but still could be forced if necessary....
rlreed is offline   Reply With Quote
Old 04-11-2014, 04:07 PM   #12
At my age, I'll still go for the door.
Old 04-11-2014, 04:38 PM   #13
Witch Doctor's Avatar
My wife opens that window which is located in the bedroom all the time. That arm that you take out of the clip will hold it about 6 to 8" from the bottom. It will not fall out. In an emergency God Forbid, you can kick it out. But you can still open it. If you look at the handle it will lock in place when open, it's the only way to hold it open. Just don't forget to close it. Just ask me why one day. In all of that it is an operative window but you need to lock the bar full open. No problem at all. But remember to close and turn the handle 90 degrees to relock it when you travel. Safe Travels this season...
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-17-2014, 06:22 AM   #14
I attended an RV boot camp in January where a fire expert highly recommended several things:
1. Practice escaping through the escape window. When I got home, I did it a couple of times. The first time was a bit awkward. The second time I realized I can easily reach the ladder once I stick my legs out (belly down). I'm really glad I did this. I have confidence that I actually can get out and hopefully without breaking any bones.
2. Open that window regularly so it doesn't get stuck.
3. Buy additional fire extinguishers. I now have one in the cockpit, one under the sink, one in the bedroom, and one in an unlocked bin outside.
4. Buy better smoke detectors.
5. If you are awakened by a smoke alarm, do not try to fight the fire. Get out. RV fires are notoriously quick burning and deadly. This expert said you may have as little as 20 seconds to get out.
Oh, he also recommended that if you have an escape window like on the FR3 where it doesn't hold itself open, buy a two-foot long dowel to keep by the window for propping it open.
For what it's worth...
Barbara
BarbaraG is offline   Reply With Quote
Old 04-17-2014, 08:12 AM   #15
PhotoMaster's Avatar
This sounds like the type we had in our 23SS. It had a single bar in the middle that locked in place to hold the window open about 10" or so. When closed it went 90 to the side and clicked into place, locking it closed. It also had a screen on it to keep the bugs out, that could easily be pulled out to escape. Really nicely designed.
The FR3 only has the bedroom emergency window and the main door. I guess you could use the front windows or the main windows in the slide out, but you'd have a nice drop to contend with. The drop would still be better than the fire.
Greg, Barbara and Cody the wonder-pup.
2014 FR3 30DS
(and 2 200cc Scooters)
PhotoMaster is offline   Reply With Quote
Old 04-17-2014, 08:18 AM   #16
Barbara
These sound like some very good ideas! I definitely like the practice fire drill idea. We did that at home when the kids were little, but never gave it a thought with our RV. Extremely good advice and things we will be doing now, too!
Thank You Barbara!
2014 FR3 30DS
Old 04-17-2014, 08:23 AM   #17
Barbara
Barb gives Good Info,practice could save your Life! Youroo!!
Old 04-18-2014, 08:12 AM   #18
Yeah, we all have this image in our minds... I'll just go out the window. Try it. If you're like me and no longer twenty-one, or even thirty-one, or forty-one, or--well, you get the picture--you will be surprised how tentative and awkward you may feel. I'm in reasonably good condition, do yoga, etc., and I found it a challenge. I mean, you have to stick your lower body out the window and at some point support yourself with you arms as you lower your feet to the bumper. That's when I decided to try the ladder, which was easier.
Another suggestion the guy gave was to draper your blanket or duvet or whatever over the window ledge. Protects a bit from hard edges and you can pull it after you and have something to wrap in if it's cold weather.
If I got nothing else out of that RV bot camp, the fire safety information was worth it. The guy who gave the class was clearly seriously committed to saving lives.
All that said, I'll also do my best not to have a fire in the first place.
B
Old 04-18-2014, 08:28 AM   #19
Herk7769's Avatar
Originally Posted by PhotoMaster View Post
Attachment 49635
Attachment 49636
Attachment 49637
Sorry for the rotation on the last one.
Phone won't let me rotate it.
I am not so sure. I don't see any hinges!
If this is the "use only in an emergency type" the window will just fall out and break. If it is one that can be opened (like mine is) there are hinges outside and a lever with a latch to prop the window open.
My dinette window looks like yours (no hinges) and if I pull that lever the window will fall out.
HAM CALLSIGN - KC3FFW
Old 04-18-2014, 08:34 AM   #20
mark0224's Avatar
Same type window in our bedroom and I do open it. We don't physically practice fire escapes but I check the exit windows to make sure they are free and will open.
mark0224 is offline   Reply With Quote
« Power Vents | 25ds »
