Old 08-09-2018, 08:27 PM   #1
FR3
External tire pressure monitoring
I'm looking into different types of tire pressure monitoring systems. Internal and external. The external seem less expensive ( doesn't require the tire to be broke down and remounted & balanced). Wondering what ya'll think about this.
Thanks in advance
Leerich is offline   Reply With Quote
Old 08-09-2018, 10:14 PM   #2
I have been using the external EEZTIRE TPMS system for 3 years, and it has worked perfectly. The peace of mind knowing the pressure and temp of all the tires, and that it will alert when there is a problem, is well worth the price!
Jim Carter
2016 FR3 30DS
jimcarterhb1951 is offline   Reply With Quote
Old 08-10-2018, 08:04 AM   #3
I have the TPMS mentioned in my signature line below. It is external. It seems to work fine. I especially like the fact that the monitor is solar powered and can sit on my dashboard without cluttering things up with a power cable. I charged it one time with the USB cable and the sun has kept it powered ever since.
/s/ George Hay Kain, III - 2018 Forest River Wildwood 254RLXL; 2013 Ford F-150 3.5 EcoBoost 4x4; ZEEPIN TPMS Solar Power Wireless Tire Pressure Monitoring System; Sherline LM 2000 - Trailer Tongue Weight Scale 2000 lb; Furrion 381556 FOS48TAPK-BL Wireless High-Speed RV Observation System.
ghkain is offline   Reply With Quote
Old 08-10-2018, 09:53 AM   #4
I don't think the ZEEPIN TPMS Solar Power Wireless Tire Pressure Monitoring System will work for Leerich's FR3. It has 6 tires, and the unit you mentioned is only for cars and trucks with 4 wheels.
Jim Carter
2016 FR3 30DS
Old 08-10-2018, 09:58 AM   #5
DavidMPDK's Avatar
X2 Love this EEZTIRE TPMS and peace of mind.
2016.5 FR3 30DS AKA "Serenity"
Searching for that perfect spot with loving Wife & 2 mini dachshunds
DavidMPDK is offline   Reply With Quote
Old 08-10-2018, 10:13 AM   #6
Coach
TST 507. It can handle any number of axles/wheels you throw at it. Included a signal booster, but I have yet to need it.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 08-10-2018, 10:41 AM   #7
I use the TST 507 and advised my brother to get it as well. He has a 39' Holiday Rambler and tows a jeep. He has sensors on the MH and the Jeep for a total of 10 wheels and doesn't even need the repeater.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 08-10-2018, 11:17 AM   #8
I use the TireMinder SMART TPMS. It is an external solution. The downside to the outside version is theft of sensors. I take mine off when the rig is in storage. Although I have not have a problem, the cost of replacement would be problematic.
Otherwise the system performance is good.
2016 RAM 3500 DRW 4x4 LB LoneStar Edition, w/Timbrens, Andersen Ultimate 2, Swift Hitch SH04 WiFi Backup/Rear View Camera
2018 Chaparral 360IBL w/Tireminder SMART TPMS, Furrion Wireless Observation System, Progressive EMS-HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
Old 08-10-2018, 11:28 AM   #9
HortMi's Avatar
I have a Tire Minder system for all six tires. It is upgradeable for when you pull a toad. It has a device that looks similar to a cell phone that I keep on the dash in its out bracket. It comes with the bracket ,charger, signal booster,extra batteries, seals and six tire monitors. Works well and has signals for slow and rapid leaks.I only have to recharge it about every four months. You may also need valve extenders. The only problem I have had was with the guy at CW who installed it for me. But it saved me from driving on an under inflated tire.CW installed the valve extenders on the rear dual wheels. After camping for a week in a campground I turned on the system and got an alarm the inside tire on the rear was low on pressure. The guy at CW had not tightened the extender and the tire only had about 20lbs of pressure left. I highly recommend one of these. It also saves time and having to get down on the ground to check air pressure.
HortMi is offline   Reply With Quote
Old 08-10-2018, 01:02 PM   #10
mads
Thanks in advance
I had two diferent êxternal tpms - the last one was the ezz one. I have switched to the Gill internal one. I never had valve stem problems before nor after using the external ones. I put the ezz one on Ebay for $299+ if you want it. I had 3 valve stems fail while using external ones.
madsledet is offline   Reply With Quote
pressure, tire
