Old 04-30-2017, 12:34 PM   #1
Antone's Avatar
False reading on fresh tank?
Anyone? We just had it filled where we are dry camping and it still says empty.
Also, anyone know where the water pump is located?
Antone is offline   Reply With Quote
Old 04-30-2017, 12:38 PM   #2
SeaDog's Avatar
I don't think the water pump has anything to do with your tank indicators, do they indicate for the other tanks? May just be a wire loose somewhere.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 04-30-2017, 12:48 PM   #3
Antone's Avatar
Thank you. All the others are reading properly.
The water pump is a separate issue. Do you know where it is?
Old 04-30-2017, 01:10 PM   #4
Left Coast
Be nice to know what you're camping in......at this point the only thing we can tell you is it's inside.....Turns out it's a FR3
Old 04-30-2017, 02:23 PM   #5
leisurelarry's Avatar
Antone,
You and I have the same rig.
Passenger side of the rig, mid-way compartment has a blank panel behind the compartment door. There is access to your water heater and water pump behind that panel. I just permanently removed the black panel (4 screws) so I have easy access to those mechanical items.
leisurelarry is offline   Reply With Quote
Old 04-30-2017, 02:31 PM   #6
asquared's Avatar
Tanks are famous for not reading correctly. Has it ever read correctly? If not then likely a wire is sitting too high on the tank or not connected properly.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 04-30-2017, 02:37 PM   #7
Antone's Avatar
2015 fr3 30ds.
Old 04-30-2017, 03:19 PM   #8
Antone's Avatar
Thank you gents. I do not know if they fresh water has ever read correctly. I filled it before we left home and when we got here it said 1/3. I can understand losing some on the road, but not that much.
Old 04-30-2017, 03:50 PM   #9
Antone's Avatar
Originally Posted by leisurelarry View Post
Antone,
Well I pulled the panel off. Pump is fine, but the tank is nearly empty. I watched a guy fill it, some came out of the overflow. We did not use any water, no leaks anywhere. It seemed like a lot of water came out the overfill. Is it possible there was so much air pressure in there it forced the water out tthe overflow? I'm really not getting it.
Old 04-30-2017, 04:00 PM   #10
It is possible that you lost most of your water through your overflow Antone. There are a few past threads regarding that very issue. I've never had a problem with it, but others needed to loop the overflow a couple of times to stop that vacuum at the top of the tank.
tank
