Old 09-12-2015, 03:26 PM   #11
That is what I just used on mine when I did it. Run a bead around the opening, screw it down, then run a bead around the edge covering the screws as you go. Should not take very long at all. To get the old vent off, I used a plastic pry tool, kinda shaped like a putty knife only about 1 inch wide, to scrape off old dicor. Works good and doesn't cut into fiberglass roof. Auto parts store carries them to remove trim from cars.
A32Deuce is online now   Reply With Quote
