Old 01-31-2019, 04:49 PM   #1
Fixed my seats today
Hi I will try to do a step by step seat fix
First I cut 2 out of the post
Then I bought a 2 7/8 outside dia. Pipe with a 3/16 wall thickness.
I wised a small square and ground my cuts so they were square on both cuts. Not perfect but close enough. The insert of the pipe will keep the post straight.
I had to grind the pipe as it was a little to snug this will take any slack out of the fit so the chair wont rattle. Then inserted the pipe into the top and bottom and drilled and taped a bolt I wised a fine thread no.8 bolt. Its over kill but safe is better than sorry. Then I installed a shim to push up the front of the seat. Its a perfect ride the passenger I cut 1 3/4 and a 5/8 shim as my wife likes to put her legs on the dash. The driver I cut 2 to 2 1/8 har to tell I had a bit of grinding to level that one. And a 1/2 filler to the front I may add a washer later but for now it 99.9% better. Im 6 and my wife is 57 theres measurement are built for us.
Good luck
Ian
ID:	195786   Click image for larger version
ID:	195787   Click image for larger version
ID:	195788   Click image for larger version
ID:	195789   Click image for larger version
Iankerr is offline   Reply With Quote
Old 01-31-2019, 06:55 PM   #2
Wow!
Nicely done!
OldGunny
2016 FR3 30ds
OldGunny is offline   Reply With Quote
