Old 12-04-2015, 11:34 AM   #1
Flexible Solar Panel install
I am wondering if anyone has installed flexible solar panels on the roof of their FR3. If so did you attach with screws or adhesive. I'm not sure if an adhesive is recommended or will work on alpha or rubber roofs.
jimcarterhb1951 is offline   Reply With Quote
Old 12-06-2015, 07:00 PM   #2
Technorick's Avatar
This spring I installed 2 100 watt panels on my 2014 FR3 using stainless screws surrounded by Dicor self leveling sealant. Then sealed around the edges with Dicor too. Posted elsewhere in this forum. Panels connect to a 1000 W go power pure sine inverter.
These are Go Power flex panels that came with the Charger regulator and the water tight wire harness. I drove 6000 miles this summer with no problems. Click image for larger version
Name:	ImageUploadedByForest River Forums1449449801.946186.jpg
No matter what panel you buy, ground test them before you install them! I got a bad unit from the factory and was happy to discover it in advance. The flex panel vendors advise pre testing before install because they know once adhered to vinyl they will damage the roof if you try to remove them.
Name:	ImageUploadedByForest River Forums1449449828.467821.jpg
Name:   ImageUploadedByForest River Forums1449449946.929923.jpg
2014 FR330 DS
Technorick is offline   Reply With Quote
Old 12-06-2015, 07:49 PM   #3
Thanks Technorick. I am installing five Go Power 100 watt panels, w/controller, 3000 watt pure sine wave inverter, inverter remote control panel, and transfer switch. Your install info and solar panel tips are appreciated. Sounds like the mounting of flex or hard panels will require about the same amount of holes in the roof.
Old 12-06-2015, 08:19 PM   #4
Blackhat6mike's Avatar
Don't know if you have already installed them as yet, but something to give thought about is if you need to remove or replace a panel, how much damage to the roof will be done? Also, with the hard panels, you can hide the wiring under each panel. If the panels are close together, no wiring is exposed. It just runs from one panel to the other underneath.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 12-07-2015, 11:53 AM   #5
If you had to replace a panel couldn't you just glue it down on top of the old panel, instead of destroying the roof?
akula1 is offline   Reply With Quote
Old 12-07-2015, 12:59 PM   #6
I just spoke to Go Power, and they said you can glue a new flexible panel over an old non functional panel, without any problem.
solar, solar panel
