Old 07-21-2018, 01:20 PM   #1
Floor
Just wondering if anyone knows how thick the floor is...I want to mount a sewer tube underneath around the propane tank and was going to drive screws in from underneath
lazbo is offline   Reply With Quote
Old 07-22-2018, 07:24 AM   #2
Carl17's Avatar
sewer pipe
I mount sewer tube over propane tank bolted to cross member steel tubing and a couple o large plastic wire ties .use wire tie for hard to reach spots rest 1/4 drilled to inch steel tubes that support body. wish i had pictures.
Carl & Bette
2018 Leprechaun
NEW YORK
Carl17 is offline   Reply With Quote
Old 07-22-2018, 07:35 AM   #3
Carl17's Avatar
This picture is from a other post but i did same thing . got tube from camping world use mount flange to bolt to coach ,tube go's all the way across coach.
Carl & Bette
2018 Leprechaun
NEW YORK
Old 07-22-2018, 09:56 PM   #4
I was going to drill into the steel support for the propane tank but thought I might cause weakness in the structure or am I just over thinking...thank you for your response.Love to get the sewer out of a box ...less smell and a bit more storage
floor
