Originally Posted by alexchuang
Thanks. I’m going to be mounting a MS2812. I just got a response from FR two minutes ago. The floor is approximately 1-5/8” thick. But the curious part is that the rep told me it is 1/2” thick osb on the coach side followed by 1” thick aluminum plate and then 1/8” luaun. Did you drill through aluminum? I mean if it is actually 1” thick aluminum...COOL! It’s better than 2” of plywood that some coaches floors are made from.
If its aluminum, its only grid frame structure, and I've never hit a frame yet. Its a wood (not sure its 1/2" though)-foam core-luan sandwich layup. So far, its held up over the last 2,000 miles. I just used fender washers for now. I first drilled the mounting pattern in some hardi-board, then mounted that on the underside of the floor. Then drill up through the floor matching that pattern. Just install 2 bolts (opposite corner) and hang your inverter. Once in place, you can push up the other 6 bolts through the floor, which will hold it in place till you tighten down everything from the top side. Holler if you need pictures or anything. Also, I hope you plan on upgraded your 120v wiring from the rear of the coach to the inverter then back to the rear distribution panel. I upgraded mine to 100 ft of 6/3 SOOW cable from the original 10/3 I believe that it was. Holler if you have questions or need pictures.
