Old 07-07-2016, 01:02 PM   #1
bes
Fog Light upgrade
I just got my ok from FR to ship out the replacement headlight assembly---has anyone also upgraded the fog light to driving lights? Is the existing wiring heavy enough for a true driving light?
Any suggestions would be great......Thanks Barry
bes is offline   Reply With Quote
Old 07-10-2016, 02:11 PM   #2
I have "upgraded" the fog lights, search under my name for the post I did on this subject last year.
The only new information is that the fog lights themselves - high quality glass lens by Hella - will crack under the heat load of a 100 watt bulb. Both of mine broke after upgrading to 100 watt h1 bulbs.
Since the main headlights are so atrociously poor, even when higher wattage bulbs are installed on my 2014. You model may not be so bad, having the fog lights brighter is the only saving grace until FR sends me a new set of headlamp housings.
Good luck, I suppose you could install any driving lamps if you choose to "upgrade".
repsolgamma is offline   Reply With Quote
light, upgrade
