Old 06-03-2017, 10:37 AM   #1
Ford vs Forest River warranty issues.
The dash A/C blower in our 2016 fr3 30ds made a loud screeching noise and stopped working about 3 weeks ago. I called the dealership and described the issue to them. They told me the dash A/C was covered by fords warranty and take it to them.
I took it to the ford service center and was called back the 2 days later telling me that the dash A/C was not covered by their contract with forest river and would provide me with the documentation to take to the dealership. (We had a couple of other things that were warranty related to get repaired as well)
I get a call from the dealership telling me that they have tested all the FR installed equipment and that is is a ford issue. The service center pulled the fan blower motor and it bench tested fine.
To be continued.
OldGunny
2016 FR3 30ds
OldGunny is offline   Reply With Quote
Old 06-03-2017, 11:27 AM   #2
SeaDog's Avatar
Sounds like the squirrel cage came off the motor or came loose. I'm sure it bench tested fine. Is it working now?
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
SeaDog is online now   Reply With Quote
Old 06-03-2017, 12:23 PM   #3
No, still inop. My first thoughts was that the fan locked up or the belt broke... We will find out!
The coach is still at the dealership getting the other warranty work completed. That should be done by next weekend. After that, I get to take it back to Ford.
OldGunny
2016 FR3 30ds
Old 06-03-2017, 08:09 PM   #4
HAPPY WHEN RV'ING
drivmsafe's Avatar
The ac components are installed to the Ford chassis at Ford. All FR does is attach the blower motor and switches to the MH body. Ask your dealer to look at the part #'s. I'm pretty sure they'll have a Ford part #. Thus, it's a Ford warranty problem.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 06-04-2017, 04:12 PM   #5
ArmyProud, Retired
Ford vs. FR warranty issues
Had the same exact issue in my 2013 FR3. Dealer repaired.
glwolf is offline   Reply With Quote
Old 06-04-2017, 04:30 PM   #6
The RV dealer reapired it?
What were the components that failed?
Thanks!
OldGunny
2016 FR3 30ds
Old 06-04-2017, 07:00 PM   #7
That problem cost me 900 Canadian when the my was 4 months olds
colourful64 is offline   Reply With Quote
Old 06-04-2017, 07:26 PM   #8
Ford vs Fr warranty
I had the same problem on my FR3. I contacted the local Ford dealer and they pulled the build sheet on my serial number. They said the heater distribution box, fan motor and controls were not part of the bare chassis and would have been provided by the final assembly manufacturer. I called FR3 service at the number on the cabinet door. They said it was a FR part but I would have to take it to a dealer. They would not sell the part to me.
Now comes the good part I contacted the dealer they told me I would need to bring it in so they could check it. They gave me a date 30 days out and said I would have to leave it for at least 5 days. If the part was bad then they would order it.
That was not acceptable to me so I pulled the motor (Mfr. Unamotor made in canada) I took it to the local Auto Zone store and the store manager and I spent about an hour trying to find a match. We found one that looked correct but when it cane in two hours later the motor was right. The mounting flange was the correct diameter, the hole pattern was not correct and the electrical connector was different. I re drilled the hole pattern, removed the connector from the original and used crimp connectors to attach it. Put it in and it is working perfect. Two hours labor, $39.99 plus tax. I did not even ask the dealer for an estimate.
Don 265 is offline   Reply With Quote
Old 06-05-2017, 01:53 PM   #9
ArmyProud, Retired
Not sure of the components that failed, but the dealer requested parts from Forest River and got approval un der warranty for the repairs. I believe they replaced the blower fan.
Old 06-05-2017, 06:31 PM   #10
Bluepill's Avatar
Ah, yes - The RV finger pointing game.
I can buy (not that I would) a Kia REO for $14K and know that everything on the car except tires is covered by Kia.
Spend 10 times that much on an RV and get the run-around.
This industry is living in the Stone Age.
Old 06-06-2017, 10:43 AM   #11
To be continued.
Hello Old Gunny,
I have had GREAT luck with Mr Nicholas Hoover @ Forest River. Call them and ask for Nick. His number is 1-574-206-7635
He helped to get me a rear rooftop ac replaced because it was damaged during installation at Forest River.
Kentucky Bob is offline   Reply With Quote
Old 06-06-2017, 10:47 AM   #12
Contact Nick Hoover at 574-206-7635
He has been great to work with on my warranty issues
Old 06-06-2017, 10:50 AM   #13
So do you expect Ford to cover warranty for what it made AND everything done by FR, or would you expect FR to cover everything they built AND what Ford manufactured? Not the same thing as buying a single vehicle built by ONE manufacturer. You are taking 2 manufacturers products and integrating their systems- expect some gray areas of warranty coverage or buy a truck and separate trailer.
Old 06-08-2017, 04:25 PM   #14
Originally Posted by Kentucky Bob View Post
Hello Old Gunny,
Good to go!
I will give him a holler depending on how things work out with the ford service center.. I have to wait for the coach to get finnished on the other stuff 1st.
I will post updates!
OldGunny
2016 FR3 30ds
Old 06-09-2017, 10:02 AM   #15
Red face Warranty issues
Hi again, I just contacted Mr. Nicholas Hoover at Forest River and he is helping me once more.
On my 2017 coach, the shower faucet is messed up.
To turn on the COLD WATER I turn the knob counter clockwise as is normal.
To turn on the HOT WATER , I need to turn the knob clockwise. That is just not right.
So I think it was supplied with 2 cold water cartridges. Mr. Hoover is sending out a new faucet to me.
This man has been GREAT to deal with.
Bob
Old 06-09-2017, 01:06 PM   #16
KYBOB....thats how my shower and my outside shower are. Knobs turn opposite. Mine is 2014 25DS. So it may not be what you think.
/wave to you from Western KY
KY25DS is offline   Reply With Quote
Old 06-26-2017, 04:13 PM   #17
I have finally called forest river, Nick Hoover (Thanks Ky Bob) and am awaiting his reply.
I have also been researching the FL lemon laws... I hope it wont come to that.
OldGunny
2016 FR3 30ds
Old 07-07-2017, 10:27 AM   #18
Hello Old Gunny,
I worked with Mr Hoover. Good scoop there Bob!
Ford worked on and found the A/C was not wired properly (where ya at FR quality control). Ended up running external wires on the outside of the wire harness to the convenience center. This got the A/C working again. When they put everything back together, it blew a relay (ford part). Ford thinks that is the fan blower motor (FR part) that has an issue that caused the relay to blow. Had to order and replace the relay and I got my rig back. I emailed Mr Hoover and they are going to refund to me the money I spent for ford to work on it.
Now, I am going out this weekend to enjoy my RV!! (and wait for the dash A/C to go out again)
When that happens.....
OldGunny
2016 FR3 30ds
Old 07-07-2017, 12:06 PM   #19
Forest River sent me 2 more faucets to replace the defective ones. Guess What...,.the repalcement faucets are bad also. I ordered 2 Dura Faucet brand faucets from Lazy Days RV in Florida. They arrived this week and they are perfect. I will install them this weekend. I will submit my bills, hoping I will be reimbursed.
The orig rear a.c. unit on my 32DS was bad & Forest River replaced it. They said I could keep the old one. I repaired it & will put it on my daughter & son in laws trailer tonight
Old 08-21-2017, 08:49 PM   #20
To be continued.
A similar problem occurred with our 2017 29 DS. On I 70 we hit a bump and the ac blower sounded like some one threw a pocket full of change into the blower. The dealership fixed the problem. A screw broke off from the blower housing and lodged in the squirrel cage. The dash board shakes so much going over bumps that it is a matter of time before it happens again. Anyone else experiencing a rattling dash board?
Gary Heeb is offline   Reply With Quote
ford, forest river, warranty
