Old 04-10-2015, 06:11 AM   #21
wayne and sherry's Avatar
Technorick can you tell us where you got that roll up screen and what all had to be done to set it up? Thanks a bunch eh.
JeNNY (2015 FR3 / 30DS)
2000 Jeep TJ Moab Rock Crawler
2013 Jeep JK
wayne and sherry is offline   Reply With Quote
Old 04-10-2015, 08:46 AM   #22
Technorick's Avatar
Posted elsewhere is another area in this forum but I don't know hoe to add a link via my iPad.
A winter project. We like air flow in the bedroom at night. And aren't prepared yet to install another AC unit in he bedroom. And wanted to prop open the rear window of the 30DS at night without getting eaten by bugs. This combined with a reversible roof vent fan should do just fine for us.
I added a retractable window screen from
www.qualitywindowscreen.com/store/retractable
The product installation assumes there is a traditional window frame and requires a one and a half inch existing wooden frame to mount the roller assembly (upside down on the top) and side slide guides to. I purchased the reverse model in bronze. That allows for space behind and between the screen allowing the pleated shade to stay in place.
So this screen box is not flush to the wall. It creates an indoor window sill also used as a shelf.
This install required i build a wooden frame about an inch wider and taller than the window on each side. I installed the retractable shade in the frame, removed the valance, installed the frame on the wall around the window with right angle clips, and replaced the valance to the frame.
The pleated shade stays so we can prop open the window with the wooden dowel, pull down the rolled up spring loaded screen (has magnets built in the base to hold it down) and still be able to use the pleated shade for privacy. These pictures show it better. I plan to add either mirror film or tinted film to the bottom half of that back window eventually.
Black marks on wall are Velcro strips to store to wooden dowel
Name:	ImageUploadedByForest River Forums1428673330.191604.jpg
Name:   ImageUploadedByForest River Forums1428673345.568153.jpg
Name:	ImageUploadedByForest River Forums1428673364.309513.jpg
Name:	ImageUploadedByForest River Forums1428673383.942599.jpg
2014 FR330 DS
Technorick is offline   Reply With Quote
Old 04-10-2015, 11:46 AM   #23
Saltyrod
Send a message via Yahoo to saltyrod
I'll see what I can do, it sounds like a great idea. Thanks.
saltyrod is offline   Reply With Quote
motorhome
