Old 02-05-2015, 01:37 PM   #1
FR3 2014
Can anyone help me with the following questions regarding my 2014 FR3 30 DS?
1. Will a sway bar help the coach from being pushed around when passed by a semi?
2. Can the drivers seat be turned completely around?
3. Can you turn off the daytime running lights?
4. During winter storage, should you use the battery disconnect and leave the coach plugged into a 110 outlet?
Sgtmac is offline   Reply With Quote
Old 02-05-2015, 02:02 PM   #2
1, I put Airtabs on mine and the difference is amazing. Even the fast semi's don't bother me now.
2. Yes, but requires getting on your hands and knees, much wrestling and a skinned knuckle or two.
3. I don't think so.
4. Judgement call, I do.
Mandoholic and Bassbabe
2014 FR3 30DS
Salem, Oregon
Mandoholic is offline   Reply With Quote
Old 02-05-2015, 02:13 PM   #3
camaraderie's Avatar
1. Don't know...but search for threads on cheap handling fix or CHP here before you invest in one.
2. Yes...the key is to realize that the seat back can be folded forward...not just upright. Then as Mandaholic says...you have to play with rotation...seat slide forward and backward and arm rest position & steering wheel up/down until you can make it around. Once you figure it out it is a lot easier the next time...after the wounds have healed!
3. No
4. No...charge battery to 100% then disconnect the negative wire. Take a voltage reading every couple of months and don't let it get below 12.3V...plug back in overnight to recharge. Alternatively...disconnect the battery and get a battery tender to keep it topped up over the winter (easier solution but not as good for the battery as the first option. ) Don't leave it on a big charger over the winter.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 02-05-2015, 08:16 PM   #4
Mandoholic,
your answer in 1, you mention "airtabs", I'm assuming you meant airbags ??
either way, which manufacture / model did you use ?
I'm look'n at something like that for a 25DS
thanks
svwc is offline   Reply With Quote
Old 02-05-2015, 09:04 PM   #5
StephanFR3's Avatar
I'm sure he ment airtabs.
StephanFR3 is offline   Reply With Quote
Old 02-05-2015, 09:07 PM   #6
StephanFR3's Avatar
Oh and I would use sumo bags before airbags. They can't leak.
