Old 08-20-2015, 10:32 AM   #1
FR3 25DS MPG; W/Prem Octane
Hello All,
Curious as to what kind of MPG 25DS owners are finding without pulling a toad.
Also has anyone experimented with using mid-grade or higher octane gas and how it effects MPG.
Thank you for your comments
dloy1324 is offline   Reply With Quote
Old 08-20-2015, 11:47 AM   #2
StephanFR3's Avatar
No, but that would just waste money. Computer controlled engines don't ping unless they are in need of maintenance. Or have been modified. Just remember if you modify you will find the weak link. My buddy's ford diesel blew his head gasket by running a chip. 2k to 3k to fix.
StephanFR3 is offline   Reply With Quote
Old 08-20-2015, 05:51 PM   #3
I've read - on one of the RV-related forums - that the low end gas (85/7-ish octane) is more appropriate for these engines. Apparently, its what they're designed for, running higher octane was (memory is fuzzy here) bad for the engine? Not beneficial enough the justify the expense? something like that.
SEGV is offline   Reply With Quote
Old 08-20-2015, 11:35 PM   #4
Thanks for the info. I hadn't thought that it might be harmful for the engine. Good to know...thanks
Old 08-20-2015, 11:40 PM   #5
StephanFR3's Avatar
It's not going to hurt, but is just a waist. The motor requires 87.
Old 08-21-2015, 06:12 AM   #6
waiter21's Avatar
I average right at 8.2 mpg, running 60-65 mph pulling a 2001 Civic.
I've never used premium in the MH as its not required.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 08-21-2015, 04:22 PM   #7
Smile fr25 fuel mileage
Just returned from a 6500 mile trip from Florida to mid western states. With all the flat, climbing up an down the rockies we Avg. 9.3 for the entire trip. Coach ran excellent. Had no problems climbing up all the steep grades, plenty of horsepower. We did not have a toad so I am sure that help. Just the Mrs an I on the trip so there wasnt a lot of weight either. I ran just reg. fuel of all different brands. Paid a low of 2.24 an a high of 3.59 throughout the entire trip . Ours is a 2015 FR25 now with 8100 miles, bought from camping world in the second week of June. Hope this helps a little.
jogalot is offline   Reply With Quote
Old 08-23-2015, 11:17 AM   #8
Higher octane fuel will have no effect on mpg, and it will not harm the engine. It is intended for high compression engines, to prevent pre-ignition (pinging). Using it in an engine that does not require it is simply a waste of money. The oil companies call it "premium" to fool customers into thinking it's a better product, and they set the price high to reap the benefits from those who fall for it.
johntaylor is offline   Reply With Quote
Old 08-24-2015, 06:11 PM   #9
johntaylor, have you ever tried conventional gas? By that I mean gasoline that has NO ethanol in it. I've run it in my personal vehicle and have noticed a 3mpg boost, but the one station that sells congas is VERY RV unfriendly(hard in and out). First chance I get to give it a shot I'll let you guys know how it works. Till then, see ya around the campfire.
PetenJeanne is offline   Reply With Quote
Old 08-24-2015, 06:41 PM   #10
StephanFR3's Avatar
That is what I run in my lawn equipment, but it is not sold a conventional gas station but at a oil supply company that does fleet sales and bulk fuel delivery. It is also 90 octane and about a dollar more per gallon. Possibly "albeit long" make sense for fuel for winter storage, but not for normal use.
25ds, mpg
