Just want to give everyone a followup on how things went after I did the cheap handling fix. I took a 400 mile trip with the FR3 last week, the difference in driving the coach is dramatic, tracks much better , side to side wobble is virtually eliminated and no noticeable difference in ride comfort. Try it you'll like it.
I did the CHF on my 25DS and it is a huge improvement. (front sway bar only). I will be doing the rear next.
No more top sway side to side and when large vehicles pass or i passed them almost no effort was needed to keep it on track. Much better this 500+ mile round trip. Was a little bit of effort to do the front but not too bad...just had to use the longer ratchets and a second jack to get it lined up. Total time was probably close to an hour but i had other things going on during this.
Highly recommend it. And best of all i could find nothing negative about the handling....only improvement.
All kidding aside, he torque spec is 68 ft/lbs I think, and my educated guess is that these were torqued to well over 250ft lbs. It took a breaker bar and a cheater bar to get mine off.
