Originally Posted by boarf16
We recently bought a 2014 FR3 30DS. I want to install 3 Maxx Fan Deluxe Fans into the coach, but conveniently this coach is not pre-wired for vent fans. I do not have any aluminum sheets to look behind, only styrofoam and more Styrofoam. I think my options are:
1. Tap into the power of the light that is just outside of the shower then run 3 wires to each of the 3 locations.
- Concerns are the amps might be too high to run 3 fans?
--It seems like the max amps the fans would draw is 4.7 amps at start up = 14.1 amps (assuming I started all three at the same time) plus the 2x 921 bulbs (which I will be replacing with LED shortly) (.1 amps x 2 bulbs) so I should be good on a 15 amp breaker...correct?
2. Somehow find a way to run wires from the house battery, up through the corner in the closet, then through the roof to center and then down the coach to each fan location.
Has anyone done a full install on the FR3 30DS?
Thanks!
Our '14 30DS was not prewired either. Here's what I did to get power.
Living area: Got power from light next to vent opening. Yes, the main light switch needs to be on to get power, but we just turn off lights at fixture if not needed.
Bedroom: Got power from 12V hot wire before light switch. Ran wire up behind molding through ceiling to vent opening. You'll need to fish a hard wire puller through the styrofoam to be able to grab wire at wall. Switch does not have to be on for fan to work.
Bathroom: Got power from light fixture in ceiling. Switch has to be on for fan to work (turn light off at fixture). Easier to do this way in my opinion.
Hope this helps.
