Old 06-06-2015, 07:04 AM   #51
Yes it takes 12 volts to the thermostat to operate the AC unit.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is offline   Reply With Quote
Old 06-06-2015, 09:12 AM   #52
PDG
PDG's Avatar
Wayne and Sherry,
Last year we experienced the southwest in July and August and just like you were miserable and unhappy how poorly our 13.5 BTU AC performed. We installed a 15k AC unit in the main cabin moved the 13.5 AC to the bedroom. Closing doors to separate the main cabin from the bath/bedroom will help you keep the main cabin cooler. We also used a fan on the floor to blow the cold air around. But in the heat of the day the single standard AC unit can't cool the coach. Sucks but reality.
Peter & Linda
2014 FR3 30DS - Fiat 500
PDG is offline   Reply With Quote
Old 06-06-2015, 09:34 AM   #53
It is well known that the FR3 has a horribly underpowered AC system. Do you have the Dometic or the Atwood? I worked with Travis Bird at FR and he replaced my Dometic with the Atwood. The Atwood is quieter, but doesn't blow as hard as the Dometic. I complained again to Travis, who then had the dealer seal off the front and rear roof caps (the AC blows into the roof, past the last vent towards the front and rear and the cold air just sits in there...very poorly engineered! Anyway, this next weekend is the first time I'll be able to test it out since they've done this. Going to be in 90 degree weather. I'm not optimistic, but I'll let you guys know how it goes.
The good things about the Atwood is that it's very quiet, even on high fan, and the heat pump is nice. If you're plugged into shore power you don't have to burn propane to keep warm.
2015 FR3 30DS
MaltnHops is offline   Reply With Quote
Old 06-06-2015, 05:22 PM   #54
Online_17's Avatar
No new AC but hope to have a lot less heat by tinting all the windows.
Online_17 is offline   Reply With Quote
Old 06-06-2015, 05:48 PM   #55
That is the key to keeping the coach cool. A windshield cover and driver side will do even more.
Old 06-06-2015, 08:57 PM   #56
wayne and sherry's Avatar
We have the Atwood. I'm going to call Travis Bird and ask him for a few minutes of his time to go over some concerns and see what he has to say! I know he is a great guy!!
JeNNY (2015 FR3 / 30DS)
2000 Jeep TJ Moab Rock Crawler
2013 Jeep JK
USS Seattle (AOE-3) 84-88 Wayne
US Army 06-15 Sherry
wayne and sherry is offline   Reply With Quote
Old 06-06-2015, 10:46 PM   #57
Travis has been amazing to work with. He has never told me "no." Make sure to have your front and rear caps sealed and see how it goes.
2015 FR3 30DS
Old 06-12-2015, 10:59 PM   #58
jbudelli's Avatar
I need air help. 2015 FR3 28DS
Since you all are air experts maybe you can help. Is the air unit supposed to work while you drive ? I can't get mine working.
I took my family to Lake Tahoe today, had to go they Sacramento at 113 degrees, the air unit upfront was really of little help but worse no air in the rest of the coach made for a very rough ride.
jbudelli is offline   Reply With Quote
Old 06-12-2015, 11:32 PM   #59
b1barnes's Avatar
It will if you run the generator and have the 30 amp plug connected to the outlet in the big storage bay. The roof top AC needs 120vac to run..
b1barnes is offline   Reply With Quote
Old 06-12-2015, 11:43 PM   #60
jbudelli's Avatar
I was told by the dealer when I bought the RV to Not run when propane is open and not with generator on. But I see other posts that say propane in to keep refrigerator cool and generators in for A/C. So this is ok to do so?
air conditioner
