Old 04-20-2014, 11:24 AM   #1
Motoring
grotto69's Avatar
FR3 Break Controller
If I want to put a break controller on my FR3, is it prewired? I'd like to do it myself if it's just a matter of connecting it. Or do I need to have it done by the pros?
Thanks.
Steve
grotto69 is offline   Reply With Quote
Old 04-20-2014, 01:06 PM   #2
HAPPY WHEN RV'ING
drivmsafe's Avatar
Hi Grotto. If you're referring to the toad brake controller, the FR3 is only prewired from the 7 wire plug to the tow vehicle ( either a 6 or 4 wire connector). The brake controller is a separate system that's wired to the toad. When wired, it will be connected to the FR3 brake lights when the pigtail is connected. There are many different types of brake controllers on the market. Depending on which one you choose will dictate if you do it yourself or take it to a pro. I bought a SMI Stay-in-Play Duo and plan on having a pro install it in my Wrangler.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 04-20-2014, 03:05 PM   #3
Motoring
grotto69's Avatar
I have a 7 plug connector at the hitch receiver. Oddly, I connected my tow dolly and the break was applied by default. I drove one mile (luckily a test run) and the tow dolly nearly caught on fire because the breaks were so hot. The grease started in the axle got so hot it shot out of the points. Still trying to understand the damage there.
I figured I should have a break controller installed since something isn't wired right at the hitch receiver if the breaks are being applied by default.
Thanks for any help.
Regards,
Grotto
Old 04-21-2014, 01:55 PM   #4
I have a Prodigy P2. Its plug and play using one of the Ford harnesses.
cucamelsmd15 is offline   Reply With Quote
Old 04-21-2014, 02:26 PM   #5
HAPPY WHEN RV'ING
drivmsafe's Avatar
I wasn't aware you were using a dolly to tow your "toad". My guess is that towing a dolly would be like towing a travel trailer (but of course much smaller). A good tow dolly should have surge or electric brakes. A Prodigy P2 is a good controller for electric. I'm not that familiar with surge brakes but if I'm not mistaken they operate on inertia, when they feel the vehicle braking. And, since the lights are outward of the tow vehicle, I don't believe the dolly needs a plug to the vehicle. If I'm wrong, I'm sure someone will jump in here.
Old 04-25-2014, 10:52 AM   #6
Motoring
grotto69's Avatar
Do you know what it will run me to install a break controller? Is the FR3 prewired?
Grotto
Old 04-25-2014, 11:22 AM   #7
HAPPY WHEN RV'ING
drivmsafe's Avatar
No, the FR3 is not prewired for a brake controller.
A Prodigy 2 is installed into your truck/mh. I had the dealer that I bought my previous TT from and they charged me $50 to install it. If you have a regular repair shop that you've been going to, they can do it for you.
Old 04-25-2014, 12:40 PM   #8
Motoring
grotto69's Avatar
I think I'm not explaining it correctly.
I have a Tow Dolly with electric brakes. The tow vehicle will ride on the tow dolly with two wheels on the dolly and two on the road (the back two). My vehicle brakes aren't going to be in play here.
When I press the brake in the RV, I want the electric brake on the tow dolly to activate. The wires to control the tow dolly brake are connected at the hitch receiver when you connect the trailer lights.
Maybe I need a different type of brake controller than what you have for a TOAD.... Sounds like its an entirely different setup. Guess I better just take it in...
ID:	50917   Click image for larger version
Old 04-25-2014, 01:34 PM   #9
HAPPY WHEN RV'ING
drivmsafe's Avatar
You explained it just fine grotto69. The Prodigy will need to be installed under the dash of the mh and wired into the trailer plug circuit at the rear so that when you plug in the dolly, it'll activate when the mh brakes are applied. The Prodigy should have come with the proper wiring and plug for under dash installation.
Like I said, I had mine installed. It's fairly simple for the pro. :-)
You're correct. The controller for my toad is totally different than yours.
Old 04-25-2014, 03:54 PM   #10
If you have the Prodigy mounted in one vehicle you can just buy another mount for the motorhome and swap the head between vehicles. I plan on moving mine between my truck at home and the RV when I need it there.
Enconcapt is offline   Reply With Quote
Old 04-26-2014, 08:22 PM   #11
Locating the cable on the Ford Chassis...
I have the prodigy brake controller for my GMC Sierra 1500. I bought the cable and holder for the Ford Chassis. Now I just need to locate the cable end to put my adapter into. Has anyone located it yet?
Thanks...
2014 FR3 25DS (Bought 2-22-2014)
Spokane, WA
wjpelka is offline   Reply With Quote
Old 04-26-2014, 08:47 PM   #12
Thanks...
Yes, its right beside the steering column. Ford supplies a pigtail to FR, so look for the pigtail. Remove the pigtail and plug in the harness for the Prodigy.
Old 05-05-2014, 08:49 AM   #13
Motoring
grotto69's Avatar
I'm here at the shop and my guys looking for the cabling for the break controller under the dash. We don't see the pigtail. Any help is appreciated.
Old 05-05-2014, 10:21 AM   #14
Its a grey plug, red, blue, green, black and yellow wires I think. Ends aren't connected to anything. It might be taped up to something else.
Show them this
https://www.fleet.ford.com/truckbbas/non-html/Q-206.pdf
Old 05-05-2014, 05:25 PM   #15
Motoring
grotto69's Avatar
Show them this
That worked very well. Hard to argue with those pics!!!
Grotto
Old 05-05-2014, 05:28 PM   #16
Motoring
grotto69's Avatar
If anyone is interested.
The F'er was pre-wired, as pointed out in earlier posts, and that made it much less expensive. The unit was about $80.00 - $90.00 and I had them install a 7 pin plug on my tow dolly, so I could pitch the adapter that I was using With all that I was out the door for $280. I was there for about 3 hours.
I went to a Trailer place (Country Boy Trailers) because I didn't want to take it to the RV place and drop it off for 2 weeks and probably be double charged.
controller
