Old 05-23-2018, 01:13 PM   #1
FR3Traveler's Avatar
FR3 Bunk Bed Fuse
Preparing to take the Grandkids to Disney World and the bunk would not go down or make any noise. Searched an old post and found the fuse location and quick solution. The bunk fuse is a 10 Amp fuse located in the coach battery compartment next to the steps. It is the only one with a 10 Amp fuse in a black holder with a center compression seal. Just sharing and wanted to thank the folks of that 2015 post.
Mark & Connie
FR3Traveler
2017 FR3 30 DS
2006 GMC Canyon (toad)
FR3Traveler is offline   Reply With Quote
Old 05-25-2018, 11:27 AM   #2
Curiouser and Curiouser
Good to know. There seems to be almost no telling where a particular fuse will be located! Thanks for sharing.
Finch
2016 FR3 30DS
Finch is offline   Reply With Quote
Old 08-03-2018, 01:42 AM   #3
It stopped for tonight and was going to lower the bunk bed in my FR3 28ds 2015 model and nothing. Took the switch out and all three wires are connected plus the two wires to the key. All other functions work such as awning, awning lights and steps. Replace the 10 amp fuse near the battery. Still nothing. The bed latches do not disengage and bed does not drop. Any ideas?
Thanks,
Bob
Dolce2017 is offline   Reply With Quote
Old 08-03-2018, 12:27 PM   #4
Thanks,
Bob
I tested and have power to and from the switch. The bed motor does not function. Are there any fuses between switch and bob no bed motors. Our friends had to spend $130 on a motel, err.
bed, bunk, fr3, fuse
