Old 04-04-2015, 08:41 AM   #1
Fr3 dash shakes
We purchased an FR3 a month ago but dont pick it up til Friday. I cant stop thinking about that dash! Itslike a flaw in the design. How did you fix this
colourful64 is offline   Reply With Quote
Old 04-04-2015, 08:38 PM   #2
fpo1123's Avatar
Fix what? I found one rattle and it was the window trim. Moved a screw over and it stopped.
MSG (Ret)
U.S. Army
Active-duty 66-92
2015 FR3 30DS
fpo1123 is offline   Reply With Quote
Old 04-04-2015, 08:51 PM   #3
The stereo part of the dash protrudes and shakes the high heavens
Old 04-05-2015, 07:59 AM   #4
fpo1123's Avatar
If you remove the panel that the radio is mounted in you should see 2 2x4 boards. If they are in there tightly you shouldn't have movement. It is a cheesy setup but it is on top of a steel frame and keeps the dash from moving. I found it one day when I was exchanging radios in my 2015 fr3 30ds.
MSG (Ret)
U.S. Army
Active-duty 66-92
2015 FR3 30DS
Old 04-05-2015, 05:55 PM   #5
Dash shakes
My Dash has only a cantilevered piece of plywood for support
2015 FR3 30DS
04 Dodge Ram
04 Mazda Speed Miata
Semper Fi
PhilZ is offline   Reply With Quote
Old 04-05-2015, 06:03 PM   #6
fpo1123's Avatar
Between the steel frame and the top of the dash I have 2 short pieces of 2x4 stacked up and it's tight. So the dash won't move easy fix.
MSG (Ret)
U.S. Army
Active-duty 66-92
2015 FR3 30DS
Old 04-07-2015, 04:45 PM   #7
We found a very simple fix for the shaking - put a plastic storage box (filled with whatever you want to store in it) underneath it. Just push it up under as far as it will go. Great storage area & no more shaking!
Grandma99
McDonough, GA
2017 Georgetown 329 DS
Grandma99 is offline   Reply With Quote
Old 04-07-2015, 06:38 PM   #8
Grandma99, we did the same but with a wicker basket...solved the shaking and I put alt of stuff in there
johnpisue is offline   Reply With Quote
