Old 09-26-2016, 08:49 PM   #11
Originally Posted by Carl17 View Post
Well it took about 4 1/2 hours to get this far . Most of time on removing old seal stuff, finish trim inside later. Yes roof needs cleaning bad but severe drought cant use water now.
I found a tape product, stickiest product I have ever seen!! 2.5 inch wide, covers the entire flange of Fantastic fan, including screw heads. Suggest you thoroughly clean a 2" strip all around the new vent, then apply the tape. I'll check my purchases and see if I can recall the name of product!!
dagcodad is offline   Reply With Quote
Old 09-26-2016, 08:56 PM   #12
It is called Eternabond, expensive but well worth it. You need 5' if tape to cover the four sides of the Fantastic fan!
Old 09-27-2016, 03:19 PM   #13
Carl17's Avatar
Smile Finish
There it is finish at last. Already use Dicor self leveling calk . Great fan make one hell of draft at high speed !
Carl & Bette
2015 FR3
NEW YORK
Carl17 is offline   Reply With Quote
Old 09-27-2016, 05:39 PM   #14
Vent wiring
Looks absolutely super! I used Dicor the first vent, but I tend to be a bit impatient so liked the tape on vents two and three. Because the tape is continuous, no chance of an air bubble. I am sure yours will work out great! Bet it's nice to have that job behind you!!
Old 10-03-2016, 09:56 AM   #15
wayne and sherry's Avatar
My 2015 30DS has no wiring that l could see for a fan in the bathroom roof vent. Or was l looking in the wrong location? I removed the inside trim around the factory hand crank roof vent and didn't see any wires.
Sent from my iPhone using Forest River Forums yo
wayne and sherry is offline   Reply With Quote
Old 10-03-2016, 10:10 AM   #16
Bathroom Fan wiring
Look carefully behind the aluminum flashing. It can be sharp, so do so carefully!
Old 10-03-2016, 01:01 PM   #17
We have a 2015 30DS and the wiring is there. I found mine on the aft side of the cutout. I had to pull out all the wires and then I found the fan wires fold up within the wire loom.
Mike
2015 FR3 30DS
KansasFR3 is offline   Reply With Quote
Old 10-04-2016, 08:49 AM   #18
Good deal guys, I'll re-visit and see if l can find them. Will the bathroom light switch also power those wires?
Old 10-04-2016, 08:52 AM   #19
Not in my 2014 FR3, but the Fantastic Fan rotary switch is easy for me and my 5'5" wife to reach. Remember the fan in the bathroom only needs to be one-way, exhaust!
Old 10-04-2016, 08:59 AM   #20
No, those wires will be hot all the time and not tied to the bathroom switch. Which is fine, since our fan has an built in on/off switch.
Mike
2015 FR3 30DS
fan, wiring
