Old 09-21-2016, 08:11 AM   #1
Carl17's Avatar
Smile FR3 fan wiring
Found wire for bathroom fan wiring brown hot ,white ground behind flashing by door in bathroom . 2015 FR3
Carl & Bette
2015 FR3
NEW YORK
Carl17 is offline   Reply With Quote
Old 09-21-2016, 08:31 AM   #2
Neat! I hope my 2015 28DS has such by the other vents as well, pulling trigger in some fantastics soon.
DutchRv is offline   Reply With Quote
Old 09-23-2016, 12:12 AM   #3
Vent wiring
I have installed Fantastic fans in all three vents, all were pre-wired. None of the pre-wiring was switched.
dagcodad is offline   Reply With Quote
Old 09-23-2016, 12:34 PM   #4
HAPPY WHEN RV'ING
drivmsafe's Avatar
That's the pisser part! FR didn't get smart until later 2015 models to figure out...DOH! we should put pre wire in the vents in case our customers want to add fans. LOL!!!
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 09-23-2016, 01:36 PM   #5
Vent wiring
Actually, mine is an early 2014 FR3 30DS!!
Old 09-23-2016, 01:46 PM   #6
HAPPY WHEN RV'ING
drivmsafe's Avatar
Wow, real!y?! Ours is also a 2014. No pre wires in any of the vents. Go figure!!
Old 09-23-2016, 02:53 PM   #7
kenandterry's Avatar
drivmsafe......
Did you check out all the way around the opening on all sides. I have a 2010 Georgetown, and found wiring a bit back in from the opening. A quick glance and I would have missed finding it.
As far as being on a switch already....no problem. I put my own switches in. I didn't want the fan to only come on if "X" was turned on.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 09-23-2016, 03:00 PM   #8
Vent wiring
Both my wife and I can easily reach the switch on the Fantastic fan so a switch seemed unnecessary. The power to the fans in all vents is not tied to the bathroom light switch.
Old 09-23-2016, 03:11 PM   #9
Dahagen
I have a 2013 Coachman Mirada and all vents had wire easy to reach once you take the plastic shroud from the old vent off. And the FR3 has no fan in the bathroom? I thought all RV's had vent fans in the toilet area. BTW...I added a remote control Maxx fan in the living room vent 'cause my wife is too short to reach the buttons.
dahagen is offline   Reply With Quote
Old 09-26-2016, 07:17 PM   #10
Carl17's Avatar
Thumbs up MaxxFan install
Well it took about 4 1/2 hours to get this far . Most of time on removing old seal stuff, finish trim inside later. Yes roof needs cleaning bad but severe drought cant use water now.
ID:	121399   Click image for larger version
ID:	121400   Click image for larger version
ID:	121401   Click image for larger version
ID:	121402   Click image for larger version
Carl & Bette
2015 FR3
NEW YORK
fan, wiring
