Old 11-04-2015, 05:08 PM   #41
A32Deuce's Avatar
Jim, I have a 2012 SunSeeker 3100SS and reading the tags under my hood, I have the v10 3 valve. My impression talking to the Ford rep at Hershey, all V10 are 3 valve. Love mine. Tow a car trailer all over the place.
A32Deuce is online now   Reply With Quote
Old 11-04-2015, 05:09 PM   #42
davel1971's Avatar
Originally Posted by Jim Schings View Post
Because of the rev limiting. They both make the same torque at ~3250 RPM. They would both make the same HP at ~5600 RPM, however one is limited to well below 5000 RPM, so it cannot do the same work in the same amount of time. The engines are identical, but the ECU just keeps you from going fast on one.... Note that HP = RPM x TORQUE / 5250. So if I reduce the maximum RPM, the engine can't get to the point where it is doing the most work (HP). A simple 2 byte modification in the ECU tables makes all the difference. Make sense?
not sure where you are getting your info from, but there are different versions of the engine and I'm pretty sure you don't have access to Fords software database to know what's in each PCM
David & Lynn
Old 11-04-2015, 05:15 PM   #43
grumpy0374's Avatar
The 3 valve V-10 did not come out until early 2005. Prior to that all vehicles that Ford made with a V-10, were the 2 valve V-10, 305-310 or so hp. Even the big class a with the Ford V-10 were 2 valve, until 2005.
The 3 valve V-10 was never and still is not available in an E-350 or E-450 Superduty van or van cut a way chassis.
The 3 valve V-10 is the standard engine for the F53 chassis. The 3 valve V-10 is also available in the F-250 and up (F-350, F-450, F-550) super duty series.
Notice I said the F Series, only.
The 3 valve 362 hp engine has never been, and is not available in an E series, nada, no-no, not ever.
If someone told you that you have a 3 valve 362 hp V-10 in your class c based motorhome, their blowing smoke up your wazzo. Unless it was a custom engine replacement, your E-450 and E-350 (optional engine) has a 2 valve 310 hp engine.
Grumpy
grumpy0374 is offline   Reply With Quote
Old 11-04-2015, 05:23 PM   #44
Jim Schings's Avatar
According to what Grumpy and others are saying here you have the 2V. I can't say one way or the other.
Jim and Katy
w/ Shelby and Sealy (Bernese Mountain Dog and a Nice Mut)
FR3
HAM CALLSIGN - AI4SR
EE, IBMer, Race Car Builder, now Retired.
Jim Schings is offline   Reply With Quote
Old 11-04-2015, 05:26 PM   #45
Boso's Avatar
X2 what Grumpy said
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 11-04-2015, 05:29 PM   #46
I don't need the Ford data base. My post was pointing out that I (or Ford) can limit the RPM ONLY and decrease peak HP. (With no other engine changes.) Every manufacture of most every engine model has done as much. This was also done on the Ford V8 Modular engines. We had a contract to change the RPM limit on all the police cars in one vicinity to get them another ~20HP. No other changes (other than speed limiter) were made.
Jim and Katy
FR3
Old 11-04-2015, 06:02 PM   #47
Ford stopped selling the 6.8 in the F250/F350 back in 2011.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 11-04-2015, 06:07 PM   #48
Kenny kustom's Avatar
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
But can still get it in 450/550
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 11-04-2015, 06:15 PM   #49
Former Full Timer
Duckogram's Avatar
... bad link...
Sorry, should have checked. Pfat fingered it.
Here is the corrected link.
https://media.ford.com/content/fordm...ries_Specs.pdf
Meanwhile, back at the ranch, is not the real issue here all about the fugazy shift strategy and little to nothing to do with the V-10?
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Old 11-04-2015, 06:21 PM   #50
grumpy0374's Avatar
Point is there are 2 seperate V-10 engines. They basically look identical, the only real difference being the head configuration, 2 valve vs. 3 valve.
2 valve is around 310 hp, while the 3 valve is around 365 hp.
Even in the E-350 and E-450 superduty chassis, either cut a way or stripped chassis, the V-10 is an option, the 5.4 V-8 being the standard engine.
In the standard E series van (regular work or passenger) the heaviest duty you can get is the E-350 and it comes with the 5.4 V-8. V-10 isn't even an option.
I wish the 3 valve was or had been an option on the cut a way...think of how your class c would run with 60 or so more hp, stock from the factory. Think of it, a 20% boost in hp. Now, that would be fun.
Grumpy
ford
