Old 11-04-2015, 06:44 PM   #51
The easy way to figure this out is by the vin number. The 8th digit is the engine model code. The V10 2 valve lower horse power engine is S . The V10 3 valve higher horse power is Y. The Y is not used in the E series. The higher RPM can disconcerting at times but as long as the temperatures don't go above normal ranges it should not be a problem.
Grumpy Guy is offline   Reply With Quote
ford
