Old 01-12-2016, 04:53 PM   #31
Originally Posted by Harleyreb View Post
Is there a quick fix to disabling the LED rings around the headlights???
Forest River wants me to pay for the new headlights, so while I argue with them, I should like to disable the LED rings for now.
Help please!
Doc
I believe in past discussions, its been reference to cut the grey wire to disable the led halos.
FR3 LED headlights
KansasFR3 is offline   Reply With Quote
Old 01-12-2016, 08:36 PM   #32
FR3 headlight replacement
There are 2 sets of wires that go to the headlight module. 1 set goes to the multi plug that powers the headlights and turn signals. The other set is 2 wires that power the LED bulbs. You have to cut those 2 and tape them off. It's the same on both sides.
dutiful Don is offline   Reply With Quote
Old 03-03-2016, 10:04 PM   #33
Just received my new replacement headlight assemblies today from Forest River. I sent an e-mail to FR on Sunday, Mar. 28th about the inadequate lighting on my 2014, FR3 28DS and asked if they would replace them with the newer ones. FR responded to my e-mail on Monday morning stating they would replace them at no charge, but I would have to replace them myself or get someone to do it for me. Three days later I received my new headlight assemblies from Forest River and I am one happy camper with FR's customers service.
My question for those that have replace their headlights is; do I need to watch out for anything out of the ordinary when replacing the HL Assy.? Also, what do I do with the two white connectors as the new lights do not have anything for them to plug into? Photo attached. As always thanks for all your help.
Mr J is offline   Reply With Quote
Old 03-04-2016, 07:10 AM   #34
If yours is like mine, the only plug you have to deal with is the big one. the white ones are part of the old headlight assembly. Once you remove the 2 bolts holding the headlight in and unplug the big plug, the whole assembly will come out except for the 4 little wires going to the LED bulbs. I cut those 4 and taped them up.
The other thing I had to do was to drill a hole in the (I believe it was) the lower plastic flange of the new lamp to allow it to be bolted to the bracket on the coach.
Then you align the lamp as best you can side-to-side and secure the bolts. There is an up-down adjustment screw on the new lamp.
I hope that helps.
Old 03-04-2016, 09:30 AM   #35
Thanks for the info. Sounds rather simple to do. Will take on the task this week if it will just warm up a little. Getting antsy to get out on the road and enjoy life.
Old 03-04-2016, 10:59 AM   #36
leisurelarry's Avatar
I'm glad to see FR continues to replace the headlamp modules for those who are asking. They sent mine to the dealer to replace them. They simply cut the wiring for the LED bulbs in the old module and taped them up. They are much better than the original modules simply because all of those silly LED lights are gone and the front of the coach doesn't appear to have its headlamps on when you turn on the awning lights. As for forward illumination, I find it a bit better (adequate) and outstanding in conjunction with the fog lamps. By the way unless you snip and tape the wires for the LED halos in the fog lamps, they will continue to come on with the awning strip. The dealer did not cut mine and I found it just a perfect amount of illumination for safe traveling around the front of the coach at night while parked.
leisurelarry is offline   Reply With Quote
Old 03-04-2016, 11:37 AM   #37
Thank you for the information on the wires. I won't clip mine until I check out the halos in the front. Would be nice to have a little extra light in the front sometimes.
Old 04-07-2016, 02:10 PM   #38
Harleyreb's Avatar
After a bit of haggling and frustration on my part, FR finally came thru and sent me a set of new assembles at no charge.
So, what have you folks done with the old headlight assemblies?
2015 FR3 30DS
2014 Jeep Cherokee Latitude
2017 Jeep Wrangler
Harleyreb is offline   Reply With Quote
Old 04-07-2016, 02:15 PM   #39
HAPPY WHEN RV'ING
drivmsafe's Avatar
Sold them on craigslist
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 04-07-2016, 05:21 PM   #40
Dealer sent mine back to FR after replacing mine.
light, replacement
