Old 04-07-2016, 07:23 PM   #41
fpo1123's Avatar
Received mine from fr the other day. Took less then 30 min to remove and install. Selling old ones on Craig's list sounds good. So drivemsafe how did you list them, and what did you get for them? Thanks.
MSG (Ret)
U.S. Army
Active-duty 66-92
2015 FR3 30DS
fpo1123 is offline   Reply With Quote
Old 04-09-2016, 02:21 PM   #42
HAPPY WHEN RV'ING
drivmsafe's Avatar
FR3 headlight replacement.
I listed them as headlight assemblies that'll fit 2007-2013 Chevy Silverado. Also added a couple of pics. I listed them for $200 for the pair. They sold for $150. Wasn't trying to make much but, it was better than nothing. 😄
BYW, my FR3 is a 2014. I know they changed the headlight assemblies in 2016
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 04-13-2016, 07:02 PM   #43
Received my replacement headlights and want to install this weekend.
Question: Those 4 wires that need to be cut and taped off....do I tape them off individually or together, like to complete a circuit if that makes sense. Apologies for the simple question, don't know much about wiring. Thank you.
JBDALHB is offline   Reply With Quote
Old 04-13-2016, 07:22 PM   #44
TApe them separately.
dutiful Don is offline   Reply With Quote
Old 04-13-2016, 07:22 PM   #45
fpo1123's Avatar
Do not tape together. You will blow fuses.
MSG (Ret)
U.S. Army
Active-duty 66-92
2015 FR3 30DS
Old 04-14-2016, 10:56 PM   #46
HAPPY WHEN RV'ING
drivmsafe's Avatar
What 4 wires are you cutting? The headlights you received should be direct plug in replacement. The only wire I taped off was to the LED's, which you won't have on the replacements.
Old 05-29-2016, 04:04 PM   #47
chideock's Avatar
Were these halo lights on 2016 models?
Considering a 2016 so would like to know what I am looking for.
Thank you
2016 Sunseeker 3010ds towing a 2013 Ford Explorer 3.5L AWD.
chideock is offline   Reply With Quote
Old 05-31-2016, 01:26 PM   #48
2016 models come with a new front cap and head lights. Not saying they're any better, but most of the conversation in this thread pertains to the 2013-2015 models. I hope the 2016's are better though.
KansasFR3 is offline   Reply With Quote
Old 05-31-2016, 01:47 PM   #49
chideock's Avatar
Thanks for the answer.
Looked at a 2016 FR3 yesterday. It did not seem to have a LED Halo ring in the headlight but then I am not sure what I was really looking for in this regard. It must have been an early 2016 because it had a 5 speed transmission in it.
Anyway the entry to the coach is too steep for my disabled dog (80lbs) to handle so an FR3 is not for us anyway. So sad.
Old 05-31-2016, 06:29 PM   #50
Clarification
I saw a post indicating Model # for replacement light was GM436-B001R or L -RV
RV. I searched on line and could only find that number without "RV". Says Chevrolet assembly. Is this correct/ only approx $ 70.00 each.
Thank u/ Bear
Bearister is offline   Reply With Quote
light, replacement
