Old 07-09-2016, 09:51 AM   #61
FR3 headlight replacement
I had to drill the hole in the bottom mounting flange. Then it can be mounted just like the original. It was a bit difficult to get the old assembly out, but it will come.
dutiful Don is offline   Reply With Quote
Old 07-09-2016, 10:24 AM   #62
Question
Figured hole would need to be drilled/ Did u take lens off to push through. I am concerned that I will damage fiberglass if I force it through. Thoughts
Bearister is offline   Reply With Quote
Old 07-09-2016, 11:24 AM   #63
Progress
Ok / Assembly is out/ However, I see wires to LED/ no problem. But in addition there are wires going from heat light to Light below (THink they are fog lights. What do i do with these wires/
Bear
Old 07-09-2016, 11:33 AM   #64
There are led lights around the fog lights as well. You can cut those too (don't see any reason to keep them) or leave them.
Old 03-16-2018, 07:27 PM   #65
Removal of fr3 headlight
After removing the top and bottom braces and few hours of trying to remove the headlight assembly through the front I discovered if you push the assembly in toward the engine it went back and out of the opening.. All I did was turn the assemble sideways and pulled it straight out..One of the adjustment screw was not working because the gear got stripped. I had to cut a square hole on top of the inside adjustment rod and push it back to toward the backside of the casing. Then I used Jb weld epoxy to attach the gear to the adjusting rod.. Works great..
perrior is offline   Reply With Quote
Old 05-07-2018, 11:44 AM   #66
AngioTech55's Avatar
Good day fellow rvers. Iíve been reading the posts and since I have a 2015 25ds, Iím experiencing the same issue with poor illumination at night. Can someone lead me to a solution either by Forest river or a do it yourself. This coach is still under warranty. Thanks in advance.
AngioTech55 is offline   Reply With Quote
Old 05-09-2018, 11:24 AM   #67
Please please report these headlights to your local safety governing body. Not only is it unsafe to have unworthy lights on a vehicle. Itís also illegal . If you go to your Forest river online Manual it will tell you exactly where to report it... it could be a matter of life
colourful64 is offline   Reply With Quote
light, replacement
