LCI's help line is outstanding if you give them a call. I had the same issue an there was a faulty harness. There is a connector that will retract the jacks when its disconected.
This the connector that will default to up if it is unplugged.
Your saying to just unplug that gadget and the jacks will automatically retract?? What is that gadget and how will the jacks just go up by unplugging it?
Attachment 120464
That plug connects to the directional valve. The directional valve will have a black & white wire leading to it. When this is unplugged the pump assembly should do nothing but retract.
Right on. Thank You. I'm going to look into it, just in case.
