Old 10-24-2014, 07:02 PM   #21
Technorick's Avatar
Does the front led lights / awning led switch run off coach batteries or chassis batteries? iE. Are you drawing down the starting battery while running the awning LEDs? or are you pulling converted DC off the converter while plugged in?
Technorick is offline   Reply With Quote
Old 04-01-2015, 01:33 PM   #22
Landshark1's Avatar
In order to deal with the LED awning, and headlight issue being connected to the same switch, I had a local RV mechanic disconnect the front headlight LED's from it.
He suggested plugging them into the headlight switch wire. So now, when the headlights go on, the front LED's go on as well (and no, it's not too bright at all). Now the LED light switch on the dash controls the awning lights only. No need to buy another switch. Both are totally separate now, and it works great.
Landshark1 is offline   Reply With Quote
Old 04-03-2015, 09:58 PM   #23
wayne and sherry's Avatar
Wow any pics of this LED mod? How do you plug the headlight LED into the headlight low beam or what ever headlight wire you taped into and how.
JeNNY (FR3/30DS)
wayne and sherry is offline   Reply With Quote
Old 04-09-2015, 09:47 PM   #24
Saltyrod
Send a message via Yahoo to saltyrod
Do you know how he did the connections, ie, hooking led to low beam? just got a 2016 28ds. However, I would like to separate the awning lights and headlight led rings. Thanks in advance.
saltyrod is offline   Reply With Quote
Old 04-10-2015, 01:13 AM   #25
Landshark1's Avatar
Hi Guys, I'm not exactly sure how he did it. I'll try and take a few pics when I have a chance and report back to you. All I know is that it works and those LED's are no longer shining on everyone in front of us when we're parked. That was a very silly design if you ask me.
Old 04-10-2015, 06:19 AM   #26
Saltyrod
Thanks, you had a great idea, can't wait to see your pics!
Old 04-11-2015, 06:30 PM   #27
Any pics on the LED / Headlight mod?
JeNNY (2015 FR3 / 30DS)
2000 Jeep TJ Moab Rock Crawler
2013 Jeep JK
Old 04-12-2015, 12:17 PM   #28
Boy. I peeked at the wires for the headlights and LED's and buckets, I'm a compleat chicken when it comes to wires. I don't see myself touching any of that.
2013 Jeep JK
Old 04-13-2015, 07:42 PM   #29
Kadiddle's Avatar
For those, especially svwc, that put a switch in to control the awning LEDs separately, I'm curious what you used for power. Did you just hook the switch to +12V? Did you need a current limiter (as LEDs sometimes do)? Where did the power come from?
BTW, new to the forum and have a new 2015 FR3 30DS. Changing mirrors, vents, and other things and hope to be more active in this forum......
Kadiddle is offline   Reply With Quote
Old 04-13-2015, 08:31 PM   #30
fpo1123's Avatar
I tapped into a constant hotwire near the stairs and ran it to the positive side of a 12v switch that I put in the cover behind the passenger seat. Sealed the old hot wire (that is connected to the dash switch for the LED lights). Now as I step out I just hit the switch near the floor and have awning lights. And hit the dash LED switch for DRL's.
MSG (Ret)
U.S. Army
Active-duty 66-92
2015 FR3 30DS
fpo1123 is offline   Reply With Quote
led, light
