Old 03-14-2014, 02:38 PM   #21
Put it in the bay next to the batteries, otherwise you'll spend a fortune on cables for it.
cucamelsmd15 is offline   Reply With Quote
Old 03-25-2014, 01:30 PM   #22
I bought the FR3 in October and parked it for the winter. Still lots, and lots of snow here in Northern Ontario (Canada). With all the issues posted on the forum, I wonder what
kind of problems I will be facing...sort of getting anxious.
johnpisue is offline   Reply With Quote
Old 03-25-2014, 02:02 PM   #23
PhotoMaster's Avatar
I put in my inverter, but noticed the ground prong wasn't grounded. I found that it was missing on the inverter. I returned it and got a new one. The New one was the same. Does anyone know why a manufacturer would choose not ground a ground pin? Otherwise it works fine. A GFCI/GFI won't be able to function without the ground, however.
Greg, Barbara and Cody the wonder-pup.
2014 FR3 30DS
(and 2 200cc Scooters)
PhotoMaster is offline   Reply With Quote
Old 04-11-2014, 10:50 AM   #24
One of my concerns with my FR3 is the risk of critters coming in where the electrical/cable comes in. (the 5"screw cap) I made this mod for the electrical/cable opening.
I took the cap from the low point drain opening (since the door covers it anyway) and cut it as shown in the comparison below
It looks like an Angel to me.
And in use it looks like this.
I still have the uncut cap for when I'm driving.
I want to do one like it for the water hookup next!
2014 FR3 30DS
Old 04-11-2014, 07:43 PM   #25
Well played. I pulled the panel for the water pump and valves, so Ill repurpose that cap too. Thanks for the idea.
Old 04-12-2014, 04:45 PM   #26
does that panel have any use? Also am I suppose to get operating instructions for my auto leveling jacks for my new 2014 FR3 . Salesman does not know.
Lfrazee is offline   Reply With Quote
Old 04-12-2014, 05:11 PM   #27
You should have a manual, which I misplaced, so I found it on line. It's put out by Lippert Components Inc. (Electronic Leveling Plus). I found two different manuals with instructions for use and installation. I'll see if I can find the links (at a campsite right now).
2014 FR3 30DS
Old 04-12-2014, 05:12 PM   #28
I did not get a manual for the power front blind or the power jacks. When I needed to re calibrate the front blind I looked up the owners manual.
Enconcapt is offline   Reply With Quote
Old 04-12-2014, 06:55 PM   #29
Other than being a PITA when trying to winterize, no, it doesnt. Well, I guess you could count aesthetics, but I prefer function over form.
Old 04-20-2014, 10:23 PM   #30
Bobb36's Avatar
I bought a electrical cable hatch that my sunseeker had and installed
2014 FR3 30DS
2014 JEEP WRANGLER WILLYS
Bobb36 is offline   Reply With Quote
Old 04-24-2014, 07:20 PM   #31
I got tired of fumbling in the dark on the power side of the back bay, so I rectified that tonight.
Soldered the power wire to the existing switch on the existing light. Ran power and ground across. I was going to put one in the middle, but its almost impossible to get far enough into the bay to mount the light.
Much easier to see whats hanging out around the power cord now.
We will be at VIR next week. I set my new diff up tonight. Hope it doesnt explode like the last one.
Old 05-04-2014, 01:14 PM   #32
Has anyone with the FR3 had any luck installing a tornado flush kit on their black water tank? I bought the kit but I am having difficulty getting access to the back side of the black tank to install the spinning head of the flush kit. Any help would be awesome!!
2014 FR3 30DS
Old 05-04-2014, 04:29 PM   #33
Online_17's Avatar
Try this, not sure if it helps but....
http://www.modmyrv.com/2008/09/28/to...ng-tank-rinser
Online_17 is offline   Reply With Quote
Old 05-15-2014, 05:02 PM   #34
I'm concerned about putting in the tank washer because I'm having difficulty getting to the tank and the tanks also have tank heaters that I don't want to damage.
2014 FR3 30DS
Old 05-15-2014, 05:26 PM   #35
Tank heaters are on the outside bottom and are not even remotely in the area of a tank washer which is mounted in the side of the tank.
cat, inverter, led, modifications
