Old 07-22-2016, 11:33 AM   #21
Originally Posted by KansasFR3 View Post
See, don't trust those dealership guys, they don't know what they're selling!
apparently - why would they!?
kerber77 is offline   Reply With Quote
Old 07-22-2016, 11:37 AM   #22
Originally Posted by DavidMPDK View Post
Have you tried the Aux setting on the unit? Usually there is an A-B setting. I haven't tried this because I haven't needed it lately. We use our computer to watch moves on the big screen using the Microsoft Wireless Display Adapter v1. http://www.amazon.com/gp/product/B00...e=UTF8&psc=1we bought on Amazon. It allows us to see the computer screen and watch movies,Youtube, work on computer etc. It's pricey, but gold IMHO. Now I'm curious also, I will have to play with the radio and if I discover a way I will post. Safe travels.
It was the aux setting on the tv - fixed it - I'm interested in the display setup you mentioned - will have to check that out - thanks!
So the outside tv will work the same? again - something the dealer said "no" to - i asked lol - again, ill go out and run the dvd and try it outside this time - much more pleased if this is the case! now, when the coach is in motion will the dvd still play to the main tv in living?
Old 08-10-2016, 08:27 AM   #23
New Speakers Outside
So I did install new speakers outside. Pyle PLMRX67. They are for sure bigger, and some cutting and grinding is needed. Other than the motorhome's body just some thin plywood and styrofoam. When done cutting and grinding, you are then inside the coach, behind the sofa (28DS) which is awesome works as speaker housing/acoustics...
When mounting, clean off plumber's putty from prior install, predrill new holes, use lots of silicone, and wipe off excess after...
$38 on Amazon.
They sound soooooo much better. I did include some pictures with measurements so for the people that do not want to cut n grind, they can use the dimensions that are there...
ID:	116806   Click image for larger version
ID:	116807   Click image for larger version
ID:	116808   Click image for larger version
ID:	116809   Click image for larger version
ID:	116811   Click image for larger version
ID:	116812   Click image for larger version
ID:	116813   Click image for larger version
DutchRv is offline   Reply With Quote
Old 08-10-2016, 09:09 AM   #24
Looks like a first class install Dutch!
Mike
2015 FR3 30DS
KansasFR3 is offline   Reply With Quote
Old 08-10-2016, 09:24 AM   #25
Thanks Mike.
And you are right, $200 more on FR's part and the FR3 could've really be more premium.
Old 08-19-2016, 03:03 PM   #26
Name:	ImageUploadedByForest River Forums1471636927.382409.jpg
ID:	117790we replaced ours w 2 JL 6.5" marine speakers and added a Bluetooth stereo controller - it sounds phenomenal!
door
