New Speakers Outside
So I did install new speakers outside. Pyle PLMRX67. They are for sure bigger, and some cutting and grinding is needed. Other than the motorhome's body just some thin plywood and styrofoam. When done cutting and grinding, you are then inside the coach, behind the sofa (28DS) which is awesome works as speaker housing/acoustics...
When mounting, clean off plumber's putty from prior install, predrill new holes, use lots of silicone, and wipe off excess after...
$38 on Amazon.
They sound soooooo much better. I did include some pictures with measurements so for the people that do not want to cut n grind, they can use the dimensions that are there...
