Old 09-26-2017, 02:27 PM   #1
FR3 Overhead Bunk
Anyone having problems with the FR 3 overhead bunk falling down because magnets cant hold the weight and torque when driving?
cbyrum is offline   Reply With Quote
Old 09-26-2017, 02:40 PM   #2
Gatch's Avatar
Are the magnets screwed up tight to the area above it? If so loosen the screw one turn. This will give the magnet a little bit of wiggle room and the bunk will stay up much better.
2015 FR3 30DS
2006 Wrangler X
Gatch is offline   Reply With Quote
Old 09-26-2017, 06:19 PM   #3
A lot of folks cut small wooden supports with rubber tips even. A 1" wooden dowl cit to length with stool feet on it works nicely.
KY25DS is offline   Reply With Quote
Old 09-27-2017, 06:41 PM   #4
Hogq's Avatar
2015 fr3 30DS, added 2nd A/C-Heat Pump, converted to 50amp, CHF with Hellwig Links, Progressive Power Management, TPMS, Blue Ox True-Center, Koni Shocks, HID Headlamps, LED Foglamps, Pioneer Stereo, Keyless entry, Auxiliary Cooling Fans for A/C Condenser.
Hogq is offline   Reply With Quote
Old 09-29-2017, 01:04 PM   #5
Overhead Bunk
Loosen the retener screw on the magnet and this will solve your problem
tinome is offline   Reply With Quote
Old 09-29-2017, 01:34 PM   #6
This is correct but hit a hard enough bump (pot hole) and it will come down. Nashville middle lane of I24 going east right before I40/I24split and i assure you it will come right down and you may utter a profanity if you manage not to bite your tongue off. The supplemental support doesnt allow the fall.
Old 09-29-2017, 04:21 PM   #7
TLAK's Avatar
Mine only fell once, I found I had not fully retracted it before I lifted it up to the magnets. Now I retract until the motor stalls, never fell again.
2015 FR3 30DS
Towing 2016 Chevy Sonic LT
TLAK is offline   Reply With Quote
Old 09-29-2017, 04:41 PM   #8
Rolling Magic's Avatar
Originally Posted by Hogq View Post
Nice.
Rolling Magic is offline   Reply With Quote
Old 09-29-2017, 05:28 PM   #9
Ive never had the front motorized section fall. But on that dang bump in the middle of the interstate i had the back magnetic part fall. Now we have addiotional drawers up there so its down all the time.
Old 09-29-2017, 10:25 PM   #10
Hogq's Avatar
Originally Posted by Rolling Magic View Post
Nice.
Thanks. 3\4inch oak dowels with polyurethane stain, pecan tint. The rubber ends are crutch tips from Walgreens. The magnets are loosened, but that does not keep a big bump from knocking the upper bunk section loose. It has bounced down so many times that it bent the slide brackets at the bunk hinge. The dowels fix the problem...
Old 09-30-2017, 08:17 AM   #11
Jim Wiemels's Avatar
Two years ago I made a set of wood dowels after seeing the idea on this forum, got all my material from Home Depot, works great and nice not having the bunk falling off the magnets all the time while driving !
Jim Wiemels is offline   Reply With Quote
Old 09-30-2017, 10:06 AM   #12
Curiouser and Curiouser
Different options are good
I too borrowed the idea of the dowels from this forum - after trying every solution suggested in this thread (along with a couple that weren't). The dowels did the trick for me, even on the horrible potholed highways in California and Texas. Other solutions may work for others.
Finch
2016 FR3 30DS
Finch is offline   Reply With Quote
Old 10-16-2017, 03:33 PM   #13
Sounds like Forest River did not put motors with brakes in them. Can someone grab me the p/n off of the motor? I want to see if I can retrofit a motor with a brake to correct this problem and I dont get my 32DS until next week.
alexchuang is offline   Reply With Quote
Old 10-16-2017, 04:12 PM   #14
Hogq's Avatar
FR3 Overhead Bunk
It's not an issue with the motor 'creeping' when the bunk is stowed. The problem is that the middle bunk hinge relies on these metal slide-stops to hold the outer bunk-leaf-segment up, and it would never be enough to support the weight of the end segment-leaf. So the factory screwed two big magnets onto the ceiling to augment the hinge-slide bracket. Well the magnets are not enough either. Sooner or later if you hit a bump, the outer leaf will break free of the magnets and bounce down about 3-5 inches. It's distracting when it happens. Keeping the magnets loose (not tightly screwed to the ceiling) helps, but sooner or later.... anyway, a couple of dowels and crutch tips will hold the leaf up and the problem is solved.
Old 10-16-2017, 07:44 PM   #15
Papaduck's Avatar
The 2018 FR3's I've looked at recently have a latch system instead of magnets.
Chuck & Donna
U.S. Army - Retired
2016 FR3 30DS w/2016 Chevy Colorado Toad
Days Camped: 2017 - 45, 2018 - 52, 2019 - 70, 2020 - ???
Papaduck is offline   Reply With Quote
bunk, fr3
