The dimmer switch has a 'stop' built in that maxes the dash brightness, if you go past that a little bit it turns the overhead lights on. I wish they'd added a separate button for it, but it was probably easier to keep it factory to fords wiring, or had something to do with the legality of it. You could probably put in a normal button too if you want to pull the panel out and touch the wiring.
