Old 09-10-2015, 05:58 PM   #91
FR3 - open storage 10x14x47 area
Opened storage area under bed ~ 10 1/2" deep x 14" high x 47" long.
Angle supports added from what was laying around - not sure needed.
Slid paneling under framing on floor prior to sawing the floor framing out.
Name:	300 4537 text.jpg
Outlet relocated. Brown duct tape used to covered the bare wood framing.
Name:	500 4545 47.jpg
FR3-Dave is offline   Reply With Quote
Old 09-13-2015, 12:21 PM   #92
I have a 2015 FR3 30DS and want to change from 30 amp to 50 amp and add an Atwood 18k BTU that FR says is on the unit (which was not on the unit, only a Dometic 15k BTU). I already used the roof holes for 3 Maxx Fan Remote fans so I will have to sacrifice the BR Maxx Air fan for another A/C. How did you change from 30 to 50 amps. I always had 50 amps on my larger units but we went down in size and do not want to go down in amps. Any pics or diagrams available. Thanks.
fedatty is offline   Reply With Quote
Old 09-13-2015, 01:34 PM   #93
I believe most just run a 20 amp extension cord to just that AC unit. Then when camping, you can use the 30 amp and 20 amp that most campgrounds offer. Or use a dog bone like this: http://www.amazon.com/Conntek-Adatpe.../dp/B002MGSNNQ.
KansasFR3 is offline   Reply With Quote
Old 09-17-2015, 06:48 PM   #94
shelves
your shelves all look great. You said you got the materials at Lowes, but what did you use to mount the shelves inside each space? Thanks
depmgt is offline   Reply With Quote
Old 09-17-2015, 06:51 PM   #95
Old 09-17-2015, 08:25 PM   #96
Landshark1's Avatar
Thank you for the kind words. I used the remnant material from the shelves to cut custom mounting brackets, and then screwed them to the inside of the cabinet. I then wood screwed the shelves to the mounting brackets. Here are a couple of photos to illustrate what I did.
Name:	ImageUploadedByForest River Forums1442535886.013472.jpg
ID:	89026Click image for larger version
Name:	ImageUploadedByForest River Forums1442535907.070073.jpg
Landshark1 is offline   Reply With Quote
Old 09-18-2015, 12:39 PM   #97
Tents2RV
Thanks for your compliment on the shelves. I am actually camping right now and am away from my records. When I return home next week I will find that info and send it to you. I can tell you that I used metal strips that are sometimes called shelf standards. They are used with matching adjustable metal clips that lock into the standards. I found a company on the internet that has a wide assortment in various lengths and colors with matching screws. Their product is also thinner than what you buy locally and look really nice. I will let you know the name of the company.
c0nnd0r is offline   Reply With Quote
Old 09-27-2015, 08:25 PM   #98
Tents2RV
Shelf Standards
The name of the company that carried the shelf standards was Woodworker's Supply. (Catalog No. 895-859). You will also see matching shelf clips and matching screws on their website. Hope this helps.
Old 10-03-2015, 12:24 PM   #99
Thanks to all for your assistance in adding shelves in the FR3. With your guidance and photos I was able to convert the coat closet into a pantry and add a shelf in the bathroom. I live in a small town so my local Lowes did not have the premade shelves in the color that matched, so I had to get raw wood and stain, but, I think it still came out great. See photos.
ID:	90552   Click image for larger version
Old 10-03-2015, 08:06 PM   #100
Tents2RV
Congrats. Your shelves look great!
modifications
