Old 04-06-2015, 04:26 PM   #11
Originally Posted by colourful64 View Post
And this bbq wont burn the side.of the rv
Originally Posted by CARMAN View Post
Does the TV still swing out & did you have to modify the mount?
The TV still swings out without a problem, BBQ hasn't heat up the sides or anything, I've used it 5 times successfully. I also pulled an extra line from the Y connector to connect an external burner, such as a Spanish paella burner in my case. Just another good easy idea.
ssaavedra is offline   Reply With Quote
Old 04-06-2015, 06:27 PM   #12
Carl17's Avatar
30 to 50 amp
Originally Posted by ssaavedra View Post
I got mine 3 months ago and I've done plenty of modifications. Here my top 6. Hope it helps
-6) 42"TV where the previous 32 was
-5) 30 Amp to 50AMP upgrade
-4) adding 2nd A/C
-3) storage on bunk bed
-2) sliding BBQ outside
-1) Washer/Dryer
Enjoy
Attachment 73118Attachment 73119Attachment 73120Attachment 73121Attachment 73122Attachment 73123
what do you have to change to go from 30 to 50 amp pictures please.
Carl & Bette
2015 FR3
NEW YORK
Carl17 is offline   Reply With Quote
Old 04-10-2015, 02:16 PM   #13
Ok can you tell me which fittings i need and where you attqched the hose for the barbecue
colourful64 is offline   Reply With Quote
Old 04-10-2015, 02:18 PM   #14
Here
Old 04-10-2015, 02:21 PM   #15
Is this what i need. Where would i attqch
Old 04-10-2015, 02:23 PM   #16
So we attaxh here
Old 04-19-2015, 08:29 PM   #17
fpo1123's Avatar
Some needed items in bedroom.
ID:	74754   Click image for larger version
ID:	74755   Click image for larger version
MSG (Ret)
U.S. Army
Active-duty 66-92
2015 FR3 30DS
fpo1123 is offline   Reply With Quote
Old 04-19-2015, 08:38 PM   #18
wayne and sherry's Avatar
Fpo1123 those are kick ass! Did you make them your self? How much would you charge to make me a set or for a copy of your plans.? I'm not much for wood working.
JeNNY (2015 FR3 / 30DS)
2000 Jeep TJ Moab Rock Crawler
2013 Jeep JK
wayne and sherry is offline   Reply With Quote
Old 04-19-2015, 08:48 PM   #19
fpo1123's Avatar
I have always said if I helped build the Ark there wouldn't be an animal alive on earth today. I just bought some wood and stain and tried. I knew I could make then 6 inches wide and went from there. I cot the legs out of the same piece of wood and attached them and then cut cross braces and sanded and stained. I think the wife thinks I can build real things now...
MSG (Ret)
U.S. Army
Active-duty 66-92
2015 FR3 30DS
Old 04-19-2015, 08:53 PM   #20
fpo1123's Avatar
But if you like I will measure and send it and the stain color and brand to you. It was simple.
MSG (Ret)
U.S. Army
Active-duty 66-92
2015 FR3 30DS
modifications
