Old 08-08-2016, 08:13 PM   #211
Twojump36, it's the iOttie Easy Touch Pad holders for the iPhone and iPad Mini I drive with. I use The app Waze as my GPS on the iPad. These holders are great - even on the bouncy FR3 dash, they stay attached.
JBDALHB is offline   Reply With Quote
Old 08-19-2016, 03:28 PM   #212
We've also added several. We tinted the windows and added the eyebrow to the front - air compressors, macerator, soap dispensers in shower , replaced all speakers plus added two in br, and a sub as well as a Bluetooth controller outside. Hubs added blind spot indicators, a camera w Dvr for front and bigger indicator lights on front corners (Peterbilt) back up leds, back up sensors, led lighting in cabinets and entry. Also the color change led strip lighting to add underneath for nighttime use. In house vac. New batteries. Sumo springs and chf. Hose adaptor and 20 ft hose for propane grill. Shade extension on order - I think that's it for now haha - oh we also added a screen door bar as I've pulled the plastic thing several times trying to catch the door. And we've added several flamingos and a lighted palm tree to the stock of needed items. and a bike rack to the rear ladder. It's too many photos to post all of it
Name:   ImageUploadedByForest River Forums1471638393.233607.jpg
Name:   ImageUploadedByForest River Forums1471638415.000496.jpg
Name:   ImageUploadedByForest River Forums1471638463.604100.jpg
Name:   ImageUploadedByForest River Forums1471638475.588927.jpg
but if anyone wants to see just ask! We've only had it a little over a month hahaha ...... But using a lot of the ideas we read on here!! And we are loving it so far 😍
kerber77 is offline   Reply With Quote
Old 08-19-2016, 03:34 PM   #213
Antone's Avatar
I also use the iOttie. Bounces like crazy, but stats attached. Waze is great.
Antone
2015 Forest River FR3 30DS - No Ragrets
Toad - 2011 Jeep Wrangler
Antone is offline   Reply With Quote
Old 08-22-2016, 08:51 PM   #214
Where did you go for a blue tooth controller outside? Pics
cnower is offline   Reply With Quote
Old 08-23-2016, 09:33 AM   #215
We purchased from a local dealer/installer - he was wiring up the extra cameras and sensors for us so had him do all of the speakers as well - but here is the unit we installed http://www.crutchfield.com/p_1369112...1643625&awdv=m and an up close of it on our coach Click image for larger version
Name:	ImageUploadedByForest River Forums1471962681.415733.jpg
ID:	118193 this was installed with the bigger JL audio speakers and an amp - all was mounted and wired just under the tv housing where there is open space - all marine grade so water and impact resistant Click image for larger version
Name:	ImageUploadedByForest River Forums1471962798.133747.jpg
Old 08-23-2016, 09:37 AM   #216
I can have hubby take pics of wiring if you like (I'm clueless there) but speakers run to the main unit inside and can be used for movies/stereo etc like the originals they or can be switched for use by phone or other Bluetooth device using the BT receiver. We added a switch to dash so the speakers outside can play music from our devices and the inside can watch a movie or listen to diff music as well at the same time
Old 10-01-2016, 03:36 PM   #217
More than I bargained for
Just completed following to 2014 FR3 31'
Convert to 50 Amp Serv.
3 /100 watt solar panels with controller
2000 watt inverter
2 6 volt batteries in series with 12 volt in parallel
Bogart Battery monitor
Second air conditioner
Have not changed out Generator / thus need to be land based to operate both Air units/ Not sure I will change this
Removed front couch/bed and booth/ Replaced with two small recliners and 2 person/desk table
Replaced/upgraded all speakers
Yes, all this was an adventure ! I will provide pictures
Pleased with result but not for the faint of heart.
Bear
Bearister is offline   Reply With Quote
Old 10-04-2016, 07:21 AM   #218
Edmo's Avatar
Good luck !!!
Edmo is offline   Reply With Quote
Old 10-10-2016, 01:23 PM   #219
kerber77,
how's the viair system working out?
nvydvrdude is offline   Reply With Quote
Old 11-30-2016, 12:29 PM   #220
per wife's request extra shelve in bath cabinet
dvd player in bedroom
ID:	125945   Click image for larger version
DutchRv is offline   Reply With Quote
modifications
