Old 06-23-2015, 01:49 PM   #61
bigduke1956's Avatar
Originally Posted by Technorick View Post
200 W Solar installed.
Attachment 80853. Attachment 80854Attachment 80855
Works well with the previously installed Go Power 1000w inverter.
Attachment 80856
2014 FR330 DS
pardon my ignorance, what does an inverter do? what are benefits, I want to learn .....TY
Mike & Sun
Pets - Piotti, Kongatti
2016 Georgetown 369 XL
US Army 22 years
Days Camped
2015 - 50+ days
bigduke1956 is offline   Reply With Quote
Old 06-23-2015, 02:00 PM   #62
Technorick's Avatar
FR3 Pictures of Mods
Power inverter converts DC from the coach battery banks to AC to enable the use of electrical appliances. When camping in a field with no hook ups the inverter can keep you from running your generator and burning fuel.
The problem is 1000w inverter will not run the air conditioner or microwave. And the inverter left to run continuously would drain the batteries. The solar array and solar charger replenishes the battery charge without having to plug in or run the generator.
IE. As long as there is sufficient sun I can run my living room tv on the 115v plug and the satellite while not plugged in to shore power and not have to run the generator. I can also run my DC powered vent fans (either while driving or sitting in a Parking lot) to keep the coach cool and know that the solar power is replenishing the coach batteries.
2014 FR330 DS
Technorick is offline   Reply With Quote
Old 06-29-2015, 04:38 PM   #63
Originally Posted by ssaavedra View Post
I got mine 3 months ago and I've done plenty of modifications. Here my top 6. Hope it helps
-6) 42"TV where the previous 32 was
-5) 30 Amp to 50AMP upgrade
-4) adding 2nd A/C
-3) storage on bunk bed
-2) sliding BBQ outside
-1) Washer/Dryer
Enjoy
Attachment 73118Attachment 73119Attachment 73120Attachment 73121Attachment 73122Attachment 73123
I have to know more about that 42" TV.
I have one ready to put in there but the holes obivously do not line up & the back of the TV does not touch the plate that it's suppsed to screw into.
I'm ready to make some modifications to get the TV to attach to the door but I would love to see how you pulled it off before I do more work than needed.
kvillars is offline   Reply With Quote
Old 07-02-2015, 03:02 PM   #64
twojump36's Avatar
Originally Posted by Go_Postal_91 View Post
Picked up my 2015 FR3 30 DS one month ago. So far I've added; bathroom shelves (Amazon.com Spice Racks), sewer hose holder over tank, wood dowels stained to match wod to support bed over cab (fell repeatedly on first trip), stop by bath mirror to keep door from hitting/breaking, hat rack, shower hooks, vent covers and other shelves throughout. Best (and most needed) was the grill insert.
Craig Thomas
US Air Force-Retired
I notice the new 2016 comes with a grill screen insert...
How did you do your grill insert?... I've been wondering how to do it and I want to keep the birds and bugs out of there.
Nice mods
twojump36 is offline   Reply With Quote
Old 07-13-2015, 05:29 PM   #65
Was your FR3 pre wired for the rear AC? If not how did you run the power to it?
red1skin1 is offline   Reply With Quote
Old 07-17-2015, 04:34 PM   #66
David and Cindy's Avatar
Smart Tiles
I, too, used Smart Tile for kitchen and bathroom backsplashes.
ID:	83200   Click image for larger version
David and Cindy
Rowdy (Shih-Poo) and Bella (Yorkie-Poo)
Howard (2016 FR3 30DS)
Toad: Ford Edge (2007)
David and Cindy is offline   Reply With Quote
Old 07-18-2015, 05:38 PM   #67
that looks great
Mike & Sun
US Army 22 years
Days Camped
2015 - 50+ days
Old 07-29-2015, 03:56 PM   #68
Post Bedroom closet (armoire) clothes rod
We wanted to replace the perforated metal strip with a regular clothes rod. But most of you know that it is difficult to attach anything to the paper-thin hollow walls. So I wanted to the method I came up with.
I made a trip to Home Depot and got the following items:
1) one ordinary 6-ft wooden clothes rod (long enough for both closets)
2) two sets of "metal closet pole sockets"
3) one roll of "Scotch Extreme Mounting Tape"
4) four free samples of cabinet material (even though they offered "walnut", I chose "antique birch" because it seemed to match the existing cabinetry color better).
I then used the tape to attach the free sample wooden squares to each closet wall. Next, I screwed the metal sockets to the wooden squares (the screws were long enough to go through the wooden square into the closet wall). Lastly, I cut the clothes rod to the to the proper length for each closet, and slid them into place.
vacationlovers is offline   Reply With Quote
Old 07-29-2015, 04:14 PM   #69
Post Kitchen cabinet shelf
We wanted to add a shelf to the kitchen cabinet above the sink.
I made a trip to Home Depot to get the following items:
1) One Rubbermaid brand 24" x 12" laminate shelf
2) One roll of Scotch Extreme mounting tape
Here's a photo of the shelf:
And here's a closeup of the label:
Here's the tape:
I cut a strip off each end of the shelf, creating two pieces 12" long by 1" wide. These would be used as supports for the shelf. I used the mounting tape to attach a support strip to the left and right walls of the cabinet.
I then the cut the shelf to the correct width (taking into account the little trim molding pieces at the front & back of the right wall), and set it on the two supports.
Here's a "before" photo:
And an "after" photo:
Old 07-29-2015, 04:24 PM   #70
Post Kitchen hand towel ring
We wanted to add a hand towel ring in the kitchen. As most of you know, it is difficult to attach anything to the paper-thin hollow cabinet walls.
I first tried using a "hollow wall anchor", but the wall is so thin that there is nothing for the anchor to grip, and it just rotated when I tried to tighten a screw.
I considered extra-strength mounting tape, but the towel ring mounting bracket didn't provide enough surface area to attach a sufficient piece of tape.
I finally decided that the only workable method was to use bolts, rather than screws. Fortunately, the back of the bolts could be accessed from inside the pantry (aka coat closet) by the door.
Here's a photo showing the bolts & nuts on the inside of the pantry:
Here's a closeup view:
And here's the finished installation:
modifications
