Old 08-06-2015, 07:22 PM   #81
fpo1123's Avatar
Looks the same as the CW one. Probably cheaper on Amazon.
MSG (Ret)
U.S. Army
Active-duty 66-92
2015 FR3 30DS
fpo1123 is offline   Reply With Quote
Old 08-30-2015, 09:09 AM   #82
Lexi2007's Avatar
Question about the towel rack
Vacationlovers, where did you place the tension towel rack? In the toilet section of the bathroom. Also, I'mconsidering putting a tension shower caddy in the shower. The area for placing shampoo and the like is ridiculously small.
Thoughts?
Advice?
Ken & Val [Lexi's mom] Moczygemba & Tori the dog
Adkins, TX
2017 Coachmen Concord 300 DS [Lexi III]
Lexi2007 is offline   Reply With Quote
Old 08-30-2015, 09:24 AM   #83
Lexi2007's Avatar
Still Learning Here
I've posted in this thread before...we traded in our 2007 FR Lexington for the 2015 FR3 30DS.
1. I've seen reference in this thread to "double-sided automotive tape" and am wondering where the best place to get it might be? O'Reilly's or Auto Zone? Is it really strong enough to support a couple of cleats and a shelf?
2. What do ya'll do about more light sockets in the front of the coach? Is there only enough juice to power just 2 or 3? I purchased one of those As Seen On TV multiple plug adapters and so far, I plan to run about a 20' extension cord from over the kitchen sink to somewhere behind the passenger seat. I plan to use hook and loop to anchor the cord in place so I can at least put a fan at the front of the coach [mine doesn't have power vents].
3. Is it possible to use a residential hand held shower head in this.
As always thanks for the advice, support and updates.
Adkins, TX
Old 08-30-2015, 11:41 AM   #84
vacationlovers's Avatar
Post
Lexi2007,
We put the towel rack in the corner (next to the bathroom door hinge). If you look closely at the first photo, you can see the holes in the wall where the original towel hook had been.
I have attached another photo, taken from the hallway, that might give you a better view.
vacationlovers is offline   Reply With Quote
Old 08-30-2015, 07:26 PM   #85
fpo1123's Avatar
Lexi2007 did you find the plug under the dash on the passenger side? I know I missed it for awhile. I also didn't know there was under the bed on the door side of the bed which is now our phone charging station.
MSG (Ret)
U.S. Army
Active-duty 66-92
2015 FR3 30DS
Old 08-30-2015, 08:13 PM   #86
Lexi2007's Avatar
Plug-icity
fpo, thank you so much for the head's up on the plugs. When we get it home tomorrow, I will definitely check it out.
Also, thank you for your service to our country.
Regards,
Kenneth & Val
Adkins, TX
Old 08-31-2015, 03:36 PM   #87
Lexi2007's Avatar
I found the plug! It was there all the time. Problem solved. I'm putting together our tension towel rack holder and installing it today. Woo Hoo
Adkins, TX
Old 08-31-2015, 06:47 PM   #88
Desert Kicker's Avatar
Added Shelving
Some shelving, sliding drawers, and under dash cabinet we added: Originally posted in another thread.
Entry Closet
Under Dinette both benches: Slides out: Original door closure: Seat Belts still attached.
Under Dash: wedged into place: no more bounce.
11-1/4" wide
9-1/2" tall in front
10" deep
7-1/2" tall in back (tapered to fit)
Bedroom Closets both sides:
Bathroom Cupboard:
Desert Kicker
2015 FR3 30DS
Desert Kicker is offline   Reply With Quote
Old 09-02-2015, 01:09 PM   #89
Seems all of owners think a like.
b1barnes is offline   Reply With Quote
Old 09-09-2015, 03:09 AM   #90
Landshark1's Avatar
I've done quite few mods to our rig. Here are some pics of the shelves that I installed.
I picked up the shelving material at Lowe's, and it matches the existing cabinets nicely. I cut all of the pieces to size on my table saw.
Name:	ImageUploadedByForest River Forums1441785809.895268.jpg
ID:	88173Click image for larger version
Name:	ImageUploadedByForest River Forums1441785824.201823.jpg
ID:	88174Click image for larger version
Name:	ImageUploadedByForest River Forums1441785836.258481.jpg
Landshark1 is offline   Reply With Quote
Old 09-10-2015, 04:58 PM   #91
FR3 - open storage 10x14x47 area
Opened storage area under bed ~ 10 1/2" deep x 14" high x 47" long.
Angle supports added from what was laying around - not sure needed.
Slid paneling under framing on floor prior to sawing the floor framing out.
Name:	300 4537 text.jpg
Outlet relocated. Brown duct tape used to covered the bare wood framing.
Name:	500 4545 47.jpg
FR3-Dave is offline   Reply With Quote
Old 09-13-2015, 11:21 AM   #92
I have a 2015 FR3 30DS and want to change from 30 amp to 50 amp and add an Atwood 18k BTU that FR says is on the unit (which was not on the unit, only a Dometic 15k BTU). I already used the roof holes for 3 Maxx Fan Remote fans so I will have to sacrifice the BR Maxx Air fan for another A/C. How did you change from 30 to 50 amps. I always had 50 amps on my larger units but we went down in size and do not want to go down in amps. Any pics or diagrams available. Thanks.
fedatty is offline   Reply With Quote
Old 09-13-2015, 12:34 PM   #93
I believe most just run a 20 amp extension cord to just that AC unit. Then when camping, you can use the 30 amp and 20 amp that most campgrounds offer. Or use a dog bone like this: http://www.amazon.com/Conntek-Adatpe.../dp/B002MGSNNQ.
KansasFR3 is offline   Reply With Quote
Old 09-17-2015, 05:48 PM   #94
shelves
your shelves all look great. You said you got the materials at Lowes, but what did you use to mount the shelves inside each space? Thanks
depmgt is offline   Reply With Quote
Old 09-17-2015, 05:51 PM   #95
Old 09-17-2015, 07:25 PM   #96
Landshark1's Avatar
Thank you for the kind words. I used the remnant material from the shelves to cut custom mounting brackets, and then screwed them to the inside of the cabinet. I then wood screwed the shelves to the mounting brackets. Here are a couple of photos to illustrate what I did.
Name:	ImageUploadedByForest River Forums1442535886.013472.jpg
ID:	89026Click image for larger version
Name:	ImageUploadedByForest River Forums1442535907.070073.jpg
Old 09-18-2015, 11:39 AM   #97
Tents2RV
Thanks for your compliment on the shelves. I am actually camping right now and am away from my records. When I return home next week I will find that info and send it to you. I can tell you that I used metal strips that are sometimes called shelf standards. They are used with matching adjustable metal clips that lock into the standards. I found a company on the internet that has a wide assortment in various lengths and colors with matching screws. Their product is also thinner than what you buy locally and look really nice. I will let you know the name of the company.
c0nnd0r is offline   Reply With Quote
Old 09-27-2015, 07:25 PM   #98
Tents2RV
Shelf Standards
The name of the company that carried the shelf standards was Woodworker's Supply. (Catalog No. 895-859). You will also see matching shelf clips and matching screws on their website. Hope this helps.
Old 10-03-2015, 11:24 AM   #99
Thanks to all for your assistance in adding shelves in the FR3. With your guidance and photos I was able to convert the coat closet into a pantry and add a shelf in the bathroom. I live in a small town so my local Lowes did not have the premade shelves in the color that matched, so I had to get raw wood and stain, but, I think it still came out great. See photos.
ID:	90552   Click image for larger version
Old 10-03-2015, 07:06 PM   #100
Tents2RV
Congrats. Your shelves look great!
modifications
