Old 07-30-2019, 07:45 PM   #1
FR3 squeaks & thud
FR3 Owners, has anyone experienced squeaks in their coach around the drivers side window. It sounds like a squeak in a wood floor. Another noise is just below and behind the drivers seat. It is a thud type of noise, usually heard when applying the brakes. Just interested in comments from other owners. Anyone with ideas on how to locate and silence these noises?
Gary
Gary Heeb is offline   Reply With Quote
Old 07-30-2019, 09:03 PM   #2
I have a squeak that originates from the bunk latch above the driver’s seat. Got it tightened and it held for a while that has started back. Something about the latch system that makes it difficult to silence.
Tiger 4416 is offline   Reply With Quote
Old 07-30-2019, 10:13 PM   #3
leisurelarry's Avatar
Gary
Try tightening the 3 wood screws that are in the track of the front shade on each side of the windshield. Eliminated all of my window squeaking. Canít help you with the thud (yet).
leisurelarry is offline   Reply With Quote
Old 07-31-2019, 02:20 AM   #4
Quality control, or lack of, seems to exist on most FR3s.
These models were built to be price leaders, at first launch. Have you seen the prices lately?
Our first edition 2014 was not immune to squeaks, rattles, hurricane force sounds, and complete un-operation of more than one system.
Hated our FR3 after its maiden trip from California to Maine and back that I was fantasizing about how quickly I could unload the jalopy onto some other poor soul.
Yet, 5 years later we still own and have come to terms on how to address the most egregious flaws while accepting others as just part of the design.
2014 had a dash that would bounce up and down at the center console 2 inches in either the up or down direction. Holy hell was that son of a gunderson loud loud loud over any road imperfection larger than a strand of hair. Only solution for the DS25 was to shove dead trees (wood) under the cross brace holding the dash radio up.
The engine cover had the fit precision of a North Korean made sledgehammer. I used incense to test airflow around the sealing edges and got a face full of patchouli driving from the blast of superheated air directly off the exhaust manifolds. The road noise that accompanied the blowtorch hot air was louder than a leaf blower with the muffler removed.
The rear sway bar was held on by bolts just 3/8 inch too long, they almost immediately loosened and departed this world - never to be seen again. This then allowed for significant thumping, grinding, popping depending if you were driving straight - right - left.
Finding the sway bar ends jackhammering their way through any solid surface they touched was concern plenty, and called for further inspection of the F53 chassis.
You know those artfully bent hydraulic brake lines from the master cylinders to the disk calipers? They are carefully routed inside the chassis ďCĒ channel, in a perfect world inhabited by anal retentive engineering types. Good luck on me, all the mounting clips holding the brake lines had been pulled out or smashed. All the brake lines looked like someone took a crowbar to them along the entire chassis length to give them at least 6 inches of space out from the center of the chassis ďCĒ channel.
Ford refused to repair or replace the damage during the 3/36 factory warranty. Since the bent lines were not leaking they found no reason for repair due to system performance. The loose brake lines left hanging down still flap around in the wind when driven at any speed above walking.
Yeah, pretty much anything that could be making noise is.
repsolgamma is offline   Reply With Quote
Old 07-31-2019, 12:48 PM   #5
twojump36's Avatar
I don't have any "squeaks" that I can hear.... I do have an extremely noisy dash or something around the dash area that I haven't been able to eliminate.
I thought it might be the front grill... not it
I thought it could be the front window shade chattering in it's track... not it
I thought it could be the upper bunk.... not it...
I thought it might be the passenger side sliding tray table... not it
I still can't figure it out.
but thankfully no squeak...
2015 FR3 30 DS
1995 Wrangler
Miles 8250
Days Camped 62
twojump36 is offline   Reply With Quote
Old 07-31-2019, 01:16 PM   #6
The top of my dash had come loose about 5 years ago. However that factory attached it from inside the engine compartment didnít hold and it was making plenty of noise. I drive two wood screws through it from the top and concealed with screw caps. Solid as a rock since and very quiet.Click image for larger version
Old 07-31-2019, 04:14 PM   #7
Gary, noise could very well be coming from dash behind radio. Remove the whole black panel that holds radio and rocker switches etc., (six or eight screws). Then try lifting dash assembly up and down to see if it moves and makes noise. Look inside and up and you will probably see a 2x4 piece of wood that supports the dash and the dash is likely no longer glued to the 2x4. Incredible huh?. I ended up refitting the whole thing and eliminated a lot of weird thumps and bangs. Noise does transfer so it may be part of your problem.
I also pushed some bat insulation all around the heater box. Open up grill and look to passenger side you will see where you can stuff insulation to the side of box and on top, being careful not to disturb temperature sensor. This will eliminate a lot of wind noise from passenger seat. Think I may have found a number of spots in engine compartment to stuff insulation in.
I was getting some terrible banging noises when going over bumps and when coach was swaying. Noise was coming from under floor boards directly under the seats. I tightened the sway bar links ( over torqued for sure) and fixed that.
As already mentioned the bunk may squeak where they latch, have someone push up or down on bunk when traveling, this is a chronic FR3 problem.
Suggest you keep a close eye on sway bar brackets and bushings front and rear. I will take a small ball peen hammer and tap all bolts and nuts everywhere, easy to tell if they are loose by the noise they make.
If you are getting a noise when you brake I would have a mechanic pull the wheel and take a close look at the calipers etc., not uncommon for the retaining bolts to come loose or break.
Good luck with your problems, when we first started out my wife spent a lot of time out of her seat trying to isolate noises. My next step will be to get some Dynamat and place inside of dog house and I think it may help to place Dynamat around air filter housing and wherever I can.
2017 FR3 28 DS
cariboo camper is offline   Reply With Quote
Old 07-31-2019, 04:54 PM   #8
Yes Cariboo you definitely should get the Dynamat. Dynamat 11905 Hoodliner 32" x 54" x 3/4" Thick Self-Adhesive Sound Deadener https://www.amazon.com/dp/B00069QLVC..._STGqDbMCR63BK
I have a 2015 30 and did the interior of dog house. I was surprised to find the exact same product already in place, but I went ahead and stuck the new Dynamat right on top of the existing. So now I have 1 1/2Ē of Dynamat in place. There was enough to stick it to some areas that the factory didnít cover with about 1 sq ft left over. I Travel over I-5 grapevine a lot so I know about engine noise. The additional application reduced the noise and heat coming from the dog house tremendously.
Old 07-31-2019, 09:38 PM   #9
Check out my post, could be your problem, actually an easy fix.
2017 FR3 28 DS
Old 07-31-2019, 09:53 PM   #10
Gary
Got to thinking, another bad squeak can develop from the coach door hinges, just lube them a bit and also the bottom panel of the screen door can rattle like crazy. A few screws in the right place will fix that.
If I ever fix all the noise in our FR3 I will probably fall asleep while driving, just kidding!
2017 FR3 28 DS
fr3
